Good Morning friend, thank you for your inquiry!
I see that you are having trouble with your Frigidaire dehumidifier displaying an error code of "F2". Typically, an "F2" error code stands for a miscommunication error. This could be a possible problem with a sensor or control panel. I would suggest performing a reset and that can be completed by disconnecting the power from your dehumidifier for roughly ten minutes. If you are still under warranty I would recommend contacting your manufacturer to see if any additional assistance can be provided. Hopefully this is helpful. -Matt
SOURCE: F2 ON THE DISPLAY / WILL NOT RUN / MODEL FDB30R1
hello sir/mam
this is because of the error in the programme so please switch OFF for 1 mint and switch ON then see the display.
SOURCE: Recently bought a Frigidaire Dehumidifier four
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
SOURCE: Frigidaire Dehumidifier gives F2 error code and no longer runs.
F1 is room temperarure sensor error. F2 is tube temperature sensor error.
The room sensor usually is located in the front of the condenser. The tube sensor is usually plugged in a tube near the condensor.
The tube temperature sensor (thermistor) should be about 10K ohms.
SOURCE: Frigidaire dehumidifier error code F2
Hello - Typically error code F2 indicates a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer to verify if the part is available and can be replace. Some do, some don't. Also confirm if the unit has a limited warranty on such concern.
