I took the handle of the vacuum apart and saw nothing that was wrong
SOURCE: Black & Decker SV1000-4 SteamBuster Vacuum
You can download the manual from the link below: http://www.dewaltservicenet.com/ServiceNet/Logon.asp You will need to register but it's free. As you know there's not much to the spray function but you should hear a pump running when you push the switch. You may need to clean the dirt bowl & filter for better results this is described in the manual. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Kirby G6 won't turn on.
If the brushead is removed,there is a safety switch which prevent the machine from operating if the brushead is removed or not installed correctly.Either this switch or the main power switch could be the culprit,as well as the cord.
SOURCE: I SERVICE/USER MANUAL FOR NILFISK VT60CR.
Some information: http://www.nilfiskcfm.com/ProductLit/VT60.PDF
Accessories list: http://www.nilfiskcfm.com/ProductLit/VTACCE_1.PDF
Otheriwse to contact a local Nilfisk rep http://www.nilfiskcfm.com/FindARep.aspx
SOURCE: AirVac ZX6000 won't turn off!
There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
SOURCE: Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
