Start up pressing F8 and select safe mode with command prompt. In the dos window type chkdsk C: /p /r If you have more than one drive or your drive is not C: then enter the drive letter required. It may ask to restart. Let it run until it finishes. This could take several hours depending on drive size or file system errors.
SOURCE: screen goes blank
Your Computer enters Stand-By mode when untouched for more than one hour. This appears to be NOT A PROBLEM but the SETTINGS need be adjusted. Follow these SIMPLE steps to resolve it: -
(1) Goto Control Panel>Power Options>Power Schemes,
(2) Set the System standby to Never.
(3) Click Apply.
(4) Click OK.
Your Problem finished.
SAHAJA YOGA IS THE ONLY GATEWAY TO THE KINGDOM OF GOD AND IS THE CULMIINATION OF ALL THE RELIGIONS AND SPIRITUAL TRADITIONS OF WORLD.
SOURCE: When I press the "On" switch nothing happens.
well how did he go around resetting the bios, did he open the device and remove the battery becuase if he did he most likely fried ur system. since the devices have power but nothing responds. however this is not applicable if the screen shows bios setttings
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
SOURCE: My HP laptop goes to HP Invent screen, and once i
Your operating system in corupted - do and F11 full destructive recovery
SOURCE: main screen password issues
remember the passward otherwise clear cmos setting from motherboard
SOURCE: Dell xps 1530 will get to log on screen and go blank
try logging in safe mode first upon turning system on tap on F8 then select safe mode, once logged in safe mode to a system restore to the date before this issue happend if system restore gives an error it failes tr going back to system restore in safe mode the do a disc defragmentation click start, accessories, system tools, system restore then select restore my computer to an earlier time then select the date when everything was working fine
Here are two views on how to create computer administrators and administration rights
When you log in screen will appear that time just press CTRL+ALT+DEL three times login page will change put there administrator and press enter if any password you put during installation of xp put that password do log in and then go to user accounts which is in control panel from there change the user rights
which you want to or
right click to my computer and go to manage and then users from there also you can set rights
Here we go just press this keys ctrl+Alt+Del it will bring you a new logging dialogue box. type the user name as administrator and leave the password blank.
press enter and there you go. that means you will log into your computer as local administrator. from there go to your control panel, click on user accounts, change my account type,
from the next stage choose administrator, click change account type
hope this helps
