Question about FUJIFILM Cameras
The screen on the camera says :turn off the camera and turn on again : but its not working at all ?
Jv500
Rosie Gee
    New Friend:
  • 113 Answers
Well, try taking out the batteries and installing them again. If that doesn't work, maybe you need new batteries.
Posted on Feb 13, 2015
NO PRINTED MANUAL FOR FUJIFILM JV500
Do a search in Google for your make and model and add the word manual, and you should be able to find a .pdf file you can download.
Jul 28, 2014 | FUJIFILM JV500BLACK FOTO.DIG. 2.7" 14MP 3X...
Fuji HS20EXR wont turn on after turning off
A defective rechargeable battery caused this on my camera, not sure about the blue haze though. Make sure battery is good or use fresh alkalines.
Mar 24, 2014 | FUJIFILM HS20 EXR Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
I formatted the lexar 48mb compactflash card
Hi there.
Take the card out of the camera while it is off, then turn it on again, if the camera works fine turn if off again and insert the card, (make sure that the write protect is off) and turn the camera on again, it may let you format the card again.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | HP Photosmart 315 Digital Camera
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Digimax L60 issue
When I turn my l60 on, the lens doesn't open all the way. Usually I just use my finger to help it along... then earlier tonight I turned on the camera again to take pictures and all I had was a white screen. I took out the battery.. then the sd card, nothing worked.
I later came online and searched for solutions.. seems this is a common problem for other cameras as well.. I tried their methods.. they say to hold the camera and just tap on it.. I tapped on the Samsung logo a few times.. the white screen was still there.. and I gave up, turned the camera back off... then decided to try again, turned it on and now I have my lcd screen working again. O_o *shrugs* I'm not going to question how it got fixed, I just hope I don't get this problem again.
Nov 18, 2007 | Samsung Digimax L60 Digital Camera
My camera stopped working
Try using rechargable batterys in it. They work good in mine.if you dont have an SD card in it, it will only take a couple of minutes of video.
Mar 07, 2007 | Vivitar ViviCam 5100 Digital Camera
Cameras Logo
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
