Question about Broan-NuTone CV450 Central Bagged Central System Vacuum
NuTone CV-353W does not turn off
Unit keeps running after manual override switch in OFF Low voltage wires disconnected> Problem Relay Switch bad! How to Replace relay? I have never done this task before. Any one who has tried doing? has done successfully, please help I am OK with some electric work, but not a pro. I have some tools, can dismount the unit from bracket, open the top. Then what next?
Posted by go2raju on
2 Related Answers
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Nutone CV 450
If the top comes off, it will be by the motor and exhaust. Just replace it with the new one, make sure you don't mix up any wires. Also unplug it from the AC first.
Posted on Jun 22, 2008
Faith
  • 95 Answers
SOURCE: I have a 3 year
A great way to check if your switch in the hose is bad would be to turn the hose sideways in the inlet. If the unit turns on you most likely need a new switch.
Posted on Jan 20, 2009
NuTone CV750 Central Vacuum won't shut off. The on/off switch on side of unit has no effect. Did continuity test on switch, it tests ok. I've disconnected the low voltage wiring at the side of unit,...
I will assume that you disconnected the switch from the circuit when you did the continuity test -- that is really important.
If so, then i think that the relay inside the top of the unit is stuck on, or the low voltage wires (inside the top) going to the relay are shorted together.
You can easily remove the top after removing 3 (or 4) screws from the upper side of the unit. Be careful to align the vents in the top with the cooling ducts from the motors when replacing the top.
Aug 31, 2010 | Broan-NuTone CV750 Central Vacuum
Will not cut off unless unpluged
You probably have a stuck relay or wires are touching. Pull the low voltage wires off the vacuum, if it keeps running it's the relay. You can try tapping with medium force next to where the low voltage wires are attached to the unit using the handle end of a hammer. Even if this works it's time to replace the circuit board. Check these guys out:
http://www.vacuumsystems.net/
Jul 04, 2010 | M&S Systems ZX-6000 Bagged Central System...
Unit will not turn off. Have to unplug it.
You probably have a stuck relay or wires are touching. Pull the low voltage wires off the vacuum, if it keeps running it's the relay. You can try tapping with medium force next to where the low voltage wires are attached to the unit using the handle end of a hammer. Even if this works it's time to replace the circuit board. Check with a local vacuum cleaner repair center. You can disconnect the pipe and low voltage wires and it should just lift straight up. Take it to the repair center so you can save service call fee, because after all it's just a large canister vacuum.
Jul 01, 2010 | M&S Systems ZX-6000 Bagged Central System...
Nutone CV353 does not shut off, think it is the relay board
You probably have a stuck relay. You can try tapping with medium force next to where the low voltage wires are attached to the unit using the handle end of a hammer. Even if this works it's time to replace the circuit board. Take the unit to a local vacuum repair center for service.
Jun 26, 2010 | Broan-NuTone CV353 Central Vacuum
Our Easy-Flo built in vacuum system will not turn off, even when the hose is disconnected. We have to turn it off manually. Could it be a short in one of the wall outlets causing this?
Some models have an on/off switch on the power unit itself. This switch is used to turn your power unit on when you are right at the machine.
If there is no switch on the power unit, unplug your power unit from the wall socket, look for two low voltage wires coming out of the power unit. These two low voltage wires are usually either attached with terminals or are tied to two wires coming out with plastic screw on wire caps. Disconnect the 2 low voltage wires. Plug your power unit back in. If the power unit does not come back on then yes, the problem is most likely a short in the outlet wiring. If the power unit still comes on with the 2 low voltage wires unattached, then the problem is in the internal circuitry of the power unit, usually a relay or some units have a circuit board with relay, circuit breaker and other components on it. The relay or circuit board will have to be replaced.
It's a little difficult to check for a short if you have multiple outlets, but if you've recently done some renovations you might start checking in that area.
May 19, 2010 | Easy Flo EF1400 Central System Vacuum
Nutone Scovill 350 will only turn off if unplugged
Some units have an on/off switch on the power unit itself. Check to make sure that is not turned on. Unplug your power unit and remove the 2 low voltage wires (not the power cord itself) . The low voltage wires start at the unit and run throught your home and attach to each hose inlet. They are usually attached to the unit by simple wire terminals or wire capped to small wires coming out. Just unlug the terminals or unscrew the wire caps and pull the connections apart. Plug your machine back in. If it still comes on the problem is the relay or circuit board/switch/ relay assembly inside the unit. If it doesn't come on with the low voltage wires unattached then you may have two wires touching somewhere in the low voltage wiring.
May 14, 2010 | Broan-NuTone CV353 Central Vacuum
My easy flo built in system wont turn on when the
If there is a switch on your hose, it may be broken.
Your system powers on from the inlets via two low voltage wires that run from the inlets to the switch/relay at the power unit. Each inlet has 2 spring loaded pins attached to the low voltage wires. In the photo below you should see these pins at the bottom of the opening, just above the door hinge. The receptacle at the top of the inlet in this photo supplies 110 volts to power your power nozzle. Not all inlets have this option, but if yours does, exercise extreme caution. Your hose must have a completely metal end or if it is a plastic end, it must have a metal band in order to short the 2 low voltage wires together to trigger the switch.
You can manually short the two low voltage pins together by using a metal pipe or needle nose pliers, just touch both pins at the same time. CAUTION: stay away from the 110 volt receptacle if present.
If your system powers on with this manual method then it would seem that the problem is in your hose.
If your system does not power on; your low voltage wires may be disconnected from the power unit or disconnected somewhere else . It's also possible that you have a bad circuit/controller board in the power unit.
May 11, 2010 | Easy Flo EF1400 Central System Vacuum
Will not turn off when hose is pulled out of wall
Jan 26, 2010 | Broan-NuTone CV450 Central Bagged Central...
the relay is most likely the problem, they get burnt and the contacts stay together leaving the unit on. Try www.builtinvacuum.com for parts.
Aug 20, 2009 | Broan-NuTone CV450 Central Bagged Central...
Nu-tone 475 keeps running even without hose plugged in.
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. Once this is done, if the tank continues to run and cannot be turned off with the switch, then most likely the relay inside is defective and needs to be replaced (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected at the vacuum tank, it can be turned off with the internal switch, then either there is a short in the low-voltage wires, or else there is a hose still plugged into an inlet somewhere. ~ TTURAMBAR
Nov 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone CV450 Central Bagged Central System Vacuum Logo
667 people viewed this question
Top Broan-NuTone Vacuums Experts
Henry Morris
Level 1 Expert
Lawrence Oravetz
robert
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
