Computers & Internet Logo
A
Anonymous Posted on Feb 13, 2015
How to fix error 2100: hdd0 - Computers & Internet
stephen Adams
Level 3:
  • Master 2,219 Answers
  • Posted on Mar 02, 2015
stephen Adams
Master
Level 3:
Answers
2219
Questions
0
Helped
354554
Points
22262
The ThinkPad system may experience a bluescreen that may only appear for a very short time, followed by a reboot. During POST, the system will display a POST 2100 error code indicating the drive cannot be initialized. The machine will not boot into the operating system.
NOTE: Powering the system fully off and then on again after 20-30 seconds will usually clear the error, but a warm reboot will not.
IT have personally experienced this issue twice so far, & Lenovo posted an advisory on this in July.
If you have encounter this issue since getting your T440 notebook, it's highly recommended to update your SSD to this new firmware.
The firmware updater is windows based, & is non-destructive (does not affect existing data) so it's easy to update.
To be absolutely safe though, it's recommended to back up your essential data before installing this firmware update.
ThinkPad may bluescreen and reboot to POST error 2100 Lenovo Support US
Also recommended is to use CCleaner registry cleaner which solves the problem temporarily.
CCleaner PC Optimization and Cleaning Free Download
1 Related Answer
ginko
Ginko
  • 19396 Answers
  • Posted on Jan 07, 2009
SOURCE: lenovo T61error 2100: HDD0(hard disk drive)
To all users with: lenovo T61error 2100: HDD0(hard disk drive),
Possible cause:
  1. Corrupted hard disk logical sectror/hard disk logical error (bad format).
  2. Hard disk connector not well in place.
  3. Hard disk broken, physical fault.
Solutions:
  1. Format hard disk and reinstall system using a Windows setup CD.
  2. If that does not work the Hard disk must be removed to check thge connector, and to test the hard disk on a different computer.
  3. If the hard disk is bad , it must be replaced, and windows reinstalled repeating step one.
When i power on it goes to window with boot menu and application menu, what do i do to get past this, bios setup
double posted
any random PC will do that when the HDD is bad
you double posted why? this post has more words
but my guess is the PC failed to boot windows
and then went to the F1 BIOS startups screen
it had 2 choices, boot or if no boots found show F1.
so it did.
and then you click startup tab below and HDD0 is missing.
f1b-cv44t0m11lwirxrgkrdmeseg-3-2_0.jpg this is your PC with a dead HDD0. if there are on words to the right
like seen at HDD2, that means the HDD0 is DEAD drive.
or missing or unplugged. if can't hear it spin that to is a dead drive. HDD0:
Re: 2100: Detection error on HDD0 (Main HDD)
It is telling you that there is a problem with your hard drive. If you know how to get to your bios screen and have a recovery CD you should be able to restore it. That is IF the hard drive is in fact not defective. Otherwise you will need to to take it to someone who does computer repair and either let them replace the hard drive or depending on your ability do so yourself or purchase another laptop
Error 2100 HDD0 Hard Disc drive initialization error (1)
Interesting.
I have only encountered this issue since using Audlogics software to remove duplicate files on my machine.
Nothing against Audlogics, I have used it before to remove duplicate images or mp3s without any problems.
This time I (maybe foolishly) scanned the entire machine and removed every duplicate file with every extension (whilst keeping an original)
Since then my machine crashes, especially when using Chrome, and gives this error upon restart. It will eventually restart.
It works fine in safe mode and does not crash at all.
I am about to go back in and try it in normal mode and run various software to see which one causes the crashes.
I'm confident that the hard drive is still fine though.
Hard drive not working..unable to boot up. Get this error message : 2100: Detection error on HDD0 (Main HDD) Press Esc to continue
Please try re-seating the hard drive.
If you look at the bottom of your laptop, along the edge there should be a screw larger then all the rest which holds a small panel. Remove this screw and panel. Remove the drive pulling lightly, with steady pressure, straight out. Place the drive back in and screw the panel back.
We had a lot of these issues, and they were often solved by just this manner alone.
Let us know if we have to go any further.
Good luck
How to fix a computer that always rebooting
check ur boot sequence in BIOS
go to BIOS
how to go to BIOS ?
while computer comes alive...before u get the Win screen press f1 / f2 / Del / Home / Ins key....try this based on ur machine...it may work the 3rd or 4th time...depends on machine to machine which key of the above brings up the BIOS...
once in BIOS...
check the boot seq.
make changes to boot seq
1 st boot - CDROM
2nd boot - USB CDROM / Floppy
3 rd boot - HDD0 / HDD1 / HDD2 etc (if u have only one Hard disk and have only one partition then it will be HDD0 else u need to check where is ur c: drive(normaly it's HDD0)
once it's done...press f10 key, it will save and exit...
else use the Save and Exit option in the BIOS menu...
restart...
1helpful
4helpful
Lenovo T61error 2100: HDD0(hard disk drive)
Possible cause:
Solutions:
1helpful
2answers
2100: HDD0 initialization error (2)
same prob on my IBM LENOVO T60
did anyone found the solution?
please contact me
i need to recover my DATA
my pc can't start no more
1helpful
Canon bjc-2100
Go to this link. Select Windows XP in the Select OS box. Download the driver and follow instructions to install the driver. Do not connect or turn on the printer until the installation program tells you to do so.
1helpful
2answers
T60 will not boot up
There appears to be a BIOS update or two available for the Lenovo TP T60. One of the updates makes reference to this error code, but the verbage afterwards is a little different to that posted here. Mind you, my recommendation is that you should stay on target with BIOS updates because they are fixing problems with the computer, even if you don't realise you are having those problems!
Please go here: http://www-307.ibm.com/pc/support/site.wss/MIGR-64462.html
Press Ctrl F and search for 2100. This tells you which update fixed a problem with ERROR 2100: At the bottom of this page you will find that these updates are for all regions. You will also find the link to the BIOS update utility.
My experience of BIOS updates on the Thinkpad range is that you have to undock the laptop prior installing the BIOS update, and ensure the laptop has a constant power support - NOT BATTERY. Ensure you read the on-screen notes carefully.
Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
