Dell Dimension 4600 PC Desktop Logo
Question about Dell Dimension 4600 PC Desktop
Cd burner makes blank cds
Ok i have vista home basic on a toshiba sat. my wmp will not burn cds anymore.i rip in a cd try to burn it to a blank and the process goes normal-showing analyzing,writing,finalizing on all songs in list.disc is then kicked out saying burn is complete.when i look at it there is no obvious burn tracks on discs and when i put it in any player it just reads"no disc".i can even put it back in computer and it will recognize it as a blank disc.i tried resetting my system with recovery discs-erasing entire hard drive.that resulted in the burner working for one day(i burned disc successfully,next day i wake up try to burn another disc with resulting failure).but here is the best part i can burn dvds(using dvd shrink 3.2) no prob.ihave even tried using my nero to import and burn cds and the result is exactly the same as with wmp.a brief look at drivers and disc player shows everything normal.please help i can give you my phone number if it would help to talk in person.
Posted by hodelizioso on
  • hodelizioso Jul 08, 2009
    i have an extra dvd drive that i had bought and installed with no change to my problem, again my comp diagnostic says the dvd drive is working properly and i can burn dvds(using dvdshrink) but not cds using wmp11 or nero.
Jerry Umali
  • 979 Answers
Try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Posted on Jul 08, 2009
  • Jerry Umali Jul 10, 2009
    if the brand new dvd drive did not work, problem can be many things, trace them one by one, 1. reinstall the OS. 2. Check for connection problems, like contacts on the dvd drive to the main board. any broken pin? loose contacts, 3. try to burn the old cd that you tried, to other pcs. the cd migth be the culprit. 4. follow my first advice, isolate it by using the external CD burner via the USb. so that we may know if the problem is software or hardware.
Burning music cd using vista and wmp...cd will not play
ImageBurn is my favorite burning software for CDs, DVDs, and Blu-Ray.
Have you tried ImageBurn?
Vista has never had the greatest reputation to begin with.
ImageBurn is free, and you can view its details on its home pagehere:
http://www.imgburn.com/
We cannot figure out how to rip and burn cds? We have loaded the software onto our Toshiba net book(NB255-N250 and see the icon but cannot figure it out. Are there instructions online? None came with...
If you have Windows Media Player (WMP), I would use that to burn CD's.
Open WMP
Click the "Burn" tab
Insert a blank disk into the drive.
Drag the songs you wish to burn from your library to the left part of the window.
Click "Burn" above where you placed your songs. (Upper right corner)
Good Luck,
Rodrick
Will burn cd-r but kicks the disk out whe I put in a blank DVD-r
Sorry but your burner is a CD-RW/DVD-ROM
this means you can burn CDs and play DVD
you cannot Burn DVD with this device.
info link here
http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=7470
Please don't forget to rate me : )
2helpful
Phillips dvd drive/cd burner does not burn cds
Might be the regestry, errors can accure throught the reg, nothing you did it just happens. Try this and see, "Start" "Run" type in "regedit" then ok in the left field click on the "+" next to Hkey_Local_Machine" + next to "System" + next to :CrurrentControlSet" + next to " Control" + next to "Class" then click on " {4D36E965-E325-11CE-BFC1-08002BE10317} " in the right fild click on "Upper Filters" then "delete" now "Lower Filters" then "Delete" restart pc. Hope this is helpfull.
1helpful
Burner does not finalize discs
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TO
  • Windows Vista Ultimate
  • Windows Vista Starter
  • Windows Vista Home Premium
  • Windows Vista Home Basic
  • Windows Vista Enterprise
  • Windows Vista Business 64-bit Edition
  • Windows Vista Ultimate 64-bit Edition
  • Windows Vista Home Premium 64-bit Edition
  • Windows Vista Home Basic 64-bit Edition
  • Windows Vista Enterprise 64-bit Edition
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information loadTOCNode(2, 'resolution'); To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/details.aspx?FamilyId=2E692102-D483-44B0-BBFF-FA87AE019CBE&displaylang=en
Please rate this a fixya
Pioneer DVD RW DVR-K17LF
You're creating Disk images on your Hard Disc Drive.
See where your CD Burning Software stores the images of the Disk and use the appropriate option to burn them onto a blank CD.
Goto www.sahajayoga.org to attain your Self realization and find a Sahaja Yoga Center to goto.
HP DVD/CD Burner 300n
Ok try this DO NOT insert the media until you have completed ya assembly... then tell it to "Burn" it will then ask for the media.. at this point insert ya CD... it should be "Detected" and ya Burn should proceed.I have had this work for me before. Also try Alcohol 120% thats a great Burner. As well as CopytoDVD...
Mehandi Husain ...
Steve Sweetleaf
Steve Sweetleaf
