Question about Staples SPL-P500 Printing Calculator
How do I load the paper in my SPL-P500 calculator?
Cut paper straight and on an angle.
James Keysor
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Try making a point and feed it in the right place, the feed roller which is only about 1/2 inch wide should pick up the paper.
Posted on Nov 07, 2017
Where can I find a user manuel for SPL-P500 calculator?
Google (brand)(SPL-P500)(manual) without parens.
Jun 18, 2018 | Office Equipment & Supplies
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
How to feed the paper into the SPL-500 and how to set for printing?
You feed it from the back,(you will see an horizontal line) you're paper has to be straight cut, than you press the arrow on the left corner until you see it on the front.
Apr 20, 2012 | Staples SPLP500 Scientific Calculator
Where can I get instruction on a spl-p500 calculator
Go to a web search page and type in spl-p500 calculator instruction manual.
May 02, 2011 | Office Equipment & Supplies
How do you load the paper on this adding machine?
    • 1 Cut the beginning of the roll of paper at a 45-degree angle with the scissors for better feeding into the Canon P23-DH V.
    • 2 Lift the paper arm up and slide the roll onto the paper arm. The cut edge of the paper should be feeding down from the outside of the roll.
    • 3 Insert the cut edge of the paper into the small **** at the back of the calculator.
    • 4 Press the feed button in the upper left area of the calculator's keyboard to feed the paper roll up through the calculator.
Jan 30, 2011 | Canon P23-DHV Calculator
How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Oct 10, 2008 | Canon P23-DHV Calculator
Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Jun 20, 2008 | Canon P23-DHV Calculator
Staples SPL-P500 Printing Calculator Logo
1,167 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
