How to remove a cassette stocked in a vhs machine?
  • Anonymous Feb 12, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is the VHS stuck on the inside and when you push eject, it wont come out?
  • David Welpton
    David Welpton Feb 20, 2019
    Yes but I got it out without damage. It wont go in properly &wont play. It makes one noise then switches itself off.
Anonymous
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Posted on Feb 12, 2015
How do I get a VHS tape out of a Go Video DVD/DCR combo?
you will have to open it up to get it out as the tape might be stuck around the play heads
Oct 23, 2017 | Televison & Video
How do i playback s-vhs compact cassettes ?
S-VHS tapes will only playback on an S-VHS machine, it will play them automatically when inserted. A normal VHS machine cannot play back an S-VHS tape.
Feb 27, 2015 | Televison & Video
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
VHS cassettes stuck NOT in a VCR. I have a few old VHS cassettes that I want to copy to DVDs. The problem is that that the tape in these cassettes gets stuck. Not only in the VCR. When I use an external...
Yes,Loosen all the VHS cassette screws from the video cassette plastic cover.Take ur finger shaking and rewine wheel a few times with it with ur finger.The VHS tapes shoud work find now.
Dec 06, 2010 | Televison & Video
Many years ago some one told me that you could put your canon video camera 8 mm tapes into a video cassete case and play them on vhs tape machine is this true cause i have many but can not get whats on...
Hello, try matelectronics.com, they have the following product, I think it's what you're looking for: VHS-C CASSETTE ADAPTER(Reference #V-0730)
VHS-C CASSETTE ADAPTER BY PHILIPS PH61300
Jul 20, 2010 | Sony Televison & Video
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Have to reassemble VHS-C cassette
Tried searching for a diagram but didn't find one. Usually the spring goes to the plastic door protecting the tape. If the door isn't retacting, you should remove the door altogether and the tape should work as long as it is moving properly when you turn the take up roller on the tape by hand.
Dec 10, 2008 | TDK TC-30HG VHS-C Tape
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
