Cars & Trucks Logo
r
randy heffner Posted on Feb 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abs/brake/ta/lights on/wont come out of park/turns signals and four ways wont workreplaced shift lock soleniod fuses are good/replaced relay/turn ing key on and push on four ways/here relay clicking real fast then quits clicking.
artie g
Level 3:
  • Cars & Trucks Master 873 Answers
  • Posted on Feb 12, 2015
artie g
Level 3:
Answers
873
Questions
0
Helped
245697
Points
2752
Check brake switch, and all brake wiring connections. Solenoid also may have series wiring from brake switch which will not allow solenoid to activate unless it is getting current from brake lights circuit telling that it is safe to take the car out of gear as long as the brake is depressed. Acuras and Honda are notorious for this type of wiring. A drop in voltage can cause these critical problems. Have your battery tested first. Sounds like a bad battery though.
1helpful
2answers
Can't shift out of park, no brake lights
This is a problem with the brake sensor lockout. Most likely it is out of place or broken and shorting. It is on the brake pedal lever.
My bturn signals wont work and abs and brake light stays on the dash??
You may have a defective turn signal switch.The brake light circuit also runs through that switch.
I have a 2000 Mercedes E430 base sedan. Last week I replaced the brake light switch because it was out and it solved the problem to the point that I can now put my car into gear and drive it, however, as...
Brake light switch problem may cause the ESP / BAS lights to illuminate.
Common symptoms of a bad
Mercedes brake light switch.
  • Car stuck in Park.
  • ABS ESP ETS lights come on.
  • Can not move the shifter from Park to Drive.
  • Brakes Defective Warning on Instrument Cluster
  • Car won't shift gears. Stuck in 2nd gear, limp mode.
  • Brake lights don't work. (Brake light switch can still be defective even if the brake lights work. Checking the brake light operation is not a good test.)
  • ESP, BAS, ABS lights turn on. Car won't shift properly. Stuck in gear.
TEST: To test your new brake light switch: Turn you car off to reset the ABS light. apply the parking brake. and start the car in neutral or park without using the brake. if the problem is the brake light switch... the light will only come on when you press the brake pedal.
If you replaced the brake light switch and the light is still on you should check a few other things such as:
  • Fuses and Relays
  • ABS pump
  • ABS wheel speed sensor
  • Brake Fluid Level
  • Get an advanced scanner to read trouble codes.
NOTE: ** You may need a MBZ scan tool to reset the error code which was stored in the ECU because of the bad brake light switch.
1995 ford ranger wont come out of park
try disconnecting the rods from the ignition switch shift lever inhibitor.this is basically the mechanism which prevents you from turning the ignition switch to the 'lock' position when the shift lever is not in the 'park' position
4helpful
2answers
Can't shift out of park, no brake lights/turn signals
Had same problem. Our trailer electric wiring harness had a bare wire that shorted when it touched the meatl trailer hitch. This blew a fuse. The fuse that it blew also control the transmission lock out thus not allowing you to shift out of park. I believe it is a 15 amp fuse. Of all the spare fuses in the van there is no 15 amp available. I took the fuse for the heated mirrors and swapped it with the blown fuse. Problem fixed but no heat for the mirrors. Better that than no tranny.
2helpful
Abs fuse
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
10helpful
4answers
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
2answers
My car (a 1991 toyota sedan le) suddenly wont shift into gear out of park.if you push the button in front of the console it will change
check all fuses,if okay check to see if brake lights work, if they work then you may have a bad shift release soleniod or maybe its just dirty and sticking.
6helpful
I need a printable image of fuse block / 97 ford windstar
your owner manual sould have fuse chart. Some fuses/ekays in enine compartment. Some in car on left side of instrument panel
in car
Fuse Amps Circuits Protected 1 10 Power Mirrors, Anti-Theft Warning Light, Diagnostic Connector 2 5 Generic Electronic Module, Start Interrupt Relay Coil 3 5 Radio Illumination, Remote Radio Illumination, Electronic Instrument Cluster, Electronic Instrument Cluster PRNDL Illumination, Electronic Instrument Cluster Switch Module, Analog Cluster Illumination, Instrument Illumination 4 — Not Used 5 — Not Used 6 15 Rear Quarter Windows (LH and RH) 7 15 High Mounted Stoplamp, Brake Shift Interlock 8 25 Subwoofer, JBL Amplifier 9 10 Park and Turn Lamps, Side Marker Lamps, License Lamps, Stop Lamps 10 2 High Beam Indicator Electronic Cluster 11 15 Park Lamps 12 10 Remote Radio, Auxiliary Warning Lamp Module, Remote Keyless Entry (RKE) Module, Anti-Theft Controller Module, Radio Illumination 13 15 Radio, CD Disc Changer 14 5 Electronic Chromatic Mirror, Analog Cluster Indicator Lamps, Air Bag Module 15 — Not Used 16 15 Horns, Horn Relay Coil 17 15 Fog Lamps 18 25 Front Wiper Motor, Front Washer Pump, Wiper/Washer Relays 19 10 Generic Electronic Module (Pin 57), Electronic Instrument Cluster 20 25 Integrated Relay Control Module, Ignition Coil 21 10 Air Bag Module, Rear Window Defrost Relay, A/C Clutch, Temp Blend Door Actuator, Brake Shift Interlock 22 20 Rear Cigar Lighter, Power Plug 23 15 Multi-Function Switch 24 20 Rear Wiper Motor, Rear Washer Pump 25 10 Turn Signal Lamps, Instrument Cluster Turn Indicator 26 15 LH Aero Headlamp, Left and Right Trailer Stop/Turn/Hazard 27 15 Hazard Warning Lamps, Instrument Cluster Turn Indicator 28 15 Instrument Panel Cigar Lighter 29 15 Battery Saver Relay, Interior Lamp Control Relay, Interior Lamps, RH and LH Keyhole Lamps 30 25 Backup Lamps, Electronic Cluster 31 10 Rear Air Suspension 32 15 RH Aero Headlamp, Trailer Park Lamps 33 15 Anti-Lock Brake (ABS) Relay, Anti-Lock Brake (ABS) Module, Daytime Running Lamp (DRL) Module 34 30 One Touch Relay, LH Window Motor 35 15 Anti-Theft Controller Module 36 30 A/C Mode Switch 37 20 Door Lock Actuators, Memory Door Lock Relay 38 15 Heated Mirrors (LH and RH) 39 30 Auxiliary Blower Motor, Ref. Valve Solenoid 40 30 Window Motor (RH) 41 5 Autolamp Relay Coils, Autolamp Sensor 42 — — 43 — — 44 — —
2helpful
2answers
ABS LIGHT ON, SHIFT LOCKED, NO BRAKE LIGHT.
If your brake lights don't work Its because you blew the fuse  which Is located In the main fuse panel under steering wheel.  Without break lights your rover will fire up nice but wont shift out of park until you replace the fuse.  If your ABS Is acting up It Is also an easy fix.  Disconnect the ABS from each wheel.  You still got all wheel disc breaks that work great but no ABS.  Your other option is  thousands of $$.  If your breaks are weak check your master cylinder and make sure you got enough fluid and that you are not loosing the fluid.  If you notice you are leaking brake fluid because you have to keep filling it up but cannot find a leak anywhere.  I bet I know where It is.  Check your rear break lines and make sure one of them didn't get caught in your rear springs and pinched ever so slightly when you were doing dounuts In the snow.
Good luck,
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
