Question about Cadet EnergyPlus 1600 watt 120/240 Volt in-wall electric heater
Fan works but no heat - Cadet EnergyPlus 1600 watt 120/240 Volt in-wall electric heater
Lawrence Oravetz
  • 10,548 Answers
Look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
Posted on Feb 12, 2015
1helpful
2answers
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
1helpful
Why won't my patio heater light
The thermocouple has to be in contact with the flame at all times when pilot is lit, this heats up and sends mill-volts back to the safety valve to keep the gas on, if not it won't let the gas through, otherwise you need to clean the pilot or replace the thermocouple if everything else is ok..
Lava heater won't light
Try using a match, sometimes spark is not hot enough. be carefulle.
My propane outdoor heater lights and generates heat on low but when i turn control to high the flame and heat do not increase
The troubleshooting manual says low fuel, low fuel and cold weather and kinked supply line. Beyond this I would need to know if something happened to the unit like it fell over or was taken apart. Best, Joe 1_31_2014_3_36_44_pm.png
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
4answers
Are electric patio heaters bad for the environment?
there has been some debate about it, in America they are seen as environmentally friendly, but in the UK they are seen as more carbon intensive
Cadet EnergyPlus 1600 watt 120/240 Volt in-wall electric heater Logo
Top Cadet Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a Cadet Patio Heater Expert? Answer questions, earn points and help others
