Question about Weiser Lock POWERBOLT ELEC DEADBOLT
The smart key deadbolt does not have an operating key so how do I reset it or get into it to rekey it.
I tried picking but unsuccessful.
2 Related Answers
Anonymous
  • 384 Answers
SOURCE: we rekeyed our deadbolt and for some reason the
The lock tang (the item between the two lock parts inside the door) has been turn 180 degree out of position. Take the lock off, turn tang 180 degrees, reassamble, and it should work like new.
Posted on Sep 01, 2009
papouducafe
  • 15 Answers
SOURCE: powerbolt lock yesterday. One problem
That a mechanical problem.. Indeed, you'd better replace the key cylinder with a new one
Posted on May 15, 2011
Rekeying house door lock
rekeying depends on the specific brand of lock you have.
The easiest solution would be to replace your current locks with the same brand. Figure out how many of which locks you want to change, ie: deadbolts, entry knobs, etc. and buy matched sets from your local hardware store. They are marked with a key code on the box...make sure they match if you want the keys to be the same.
Nov 16, 2014 | Locks & Locksmithing
How do i rekey the deadbolt to fit the doorknob key?
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Dec 13, 2009 | Kwikset Locks & Locksmithing
Kwikset smart key has no key. need to rekey. how do I do that
Here is the instructions from kwiksets website
http://www.kwikset.com/Files/PDF/SmartSeries/SmartKeyInsEnglishOnly.pdf
Oct 13, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Key won't turn deadbolt
Try using your smartkey to "rekey" the lock to the original key... there's really no reason to buy the smartkey system unless you change locks alot... they are meant for the apartment industry more than anything I believe... in any case, the smartkey system allows you to rekey the lock without removing it from the door... so, use the original key and use the smartkey to rekey it or select a different cut and key it to that key... should solve your problem.
Last resort... take it back to HD for replacement.
Sep 09, 2009 | Kwikset Locks & Locksmithing
I bought 2 kwikset deadbolts.The first one worked out fine.The second one I turn the original key by accident.Now neither key will work.Is there a way to rekey my original key.
put the 'dummy key' that came in with it, turn it a 1/4 turn right, put smart key in, pull out smart key. pull out the key and insert the key that you would have as a desired key and turn left 1/4. thats it!!!!!!
Jul 20, 2009 | Kwikset Locks & Locksmithing
Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
May 21, 2009 | Kwikset Professional Door Lock...
I have several ''gatehouse'' deadbolts and i can't get the core out in order to rekey them. how can i get it out or find instructions?
Here is a link to the manual for rekeying all Schlade/Gatehouse locks.(It's in PDF format)You can download,save,print,or view online.
Please take time to rate this fixya
May 14, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Need to have a master key for all locksets
Any locksmith can rekey the locks to a single Master. Some make house calls, but it costs less to take them off and take them if this is feasible.
Mar 01, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
132 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
