Question about Wells F-49 21148 Deep Fryer
How do I trouble shoot a wells f49 deep fryer? With the power on the high limit light comes on when the temp is turned up and the limit switch does not need reset.
The light limit does not reset. The heat light and the high limit lights come on when the thermostat is turned up.
5 Related Answers
Anonymous
  • 136 Answers
SOURCE: frequent tripping of the hight limit switch
The high limit switch itself is getting weak , replace it and problem solved!
Posted on Sep 15, 2007
Anonymous
  • 505 Answers
SOURCE: please help
the the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
Posted on Jul 18, 2008
bigg t
anthony james
  • 640 Answers
SOURCE: wells deep fryer won't heat
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
Posted on Mar 22, 2009
Anonymous
  • 125 Answers
SOURCE: fryer isn't turning on. tried reseting. still no luck
Hello. Here is a wiring diagram for your unit:
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307298.pdf
Check to see that the thermostat clicks at or about just above on, try again the reset, sometimes it is hard to push in all the way. If that does not correct the problem, make sure your power is on, do any indicators light? It could be as simple as a burnt of wire, you will need to check the resistance of the parts to tell any more, thermostat, and hi-limit should read closed (zero). The element should read 4 to 15 ohms each, there are 3 in the tube. The relay coil should be anywhere from 200 to 1200 ohms, the contacts open. I have seen broken wires in the pivot elbow where power comes up the the element head.
Hope that helped, and thank you.
If you need more help, "ask me"
Posted on Apr 19, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Hi I believe I have
Running the fryer with no oil will over heat the coil very quickly...this caused the element to burn out...
That element will be replaceable...
If you call these guys you should be able to purchase a new element from them...
http://www.fryerworld.com/wells-f49.html
heatman101
Posted on Nov 23, 2010
Replaced the thermostats and high limit switches on both sides of a double vat unit. One thermostat blew immediately when the power was turned on. Blew like burned the guts out of it. This side is now dead...
Hi there, it seems that the wiring is messed up. For wiring diagram, you may visit www.wells-bloomfield search for your fryer model and you may be able to download it free.
Jan 30, 2014 | Wells F-67 21167 Deep Fryer
Can not get fryer to turn on. when you flip the switch to the on position, the high limit light flashes and go back off emediatly, and no power comes back on. i can here a click in the board behind the...
The High Limit is a self resetting thermostat that acually works like an oven control. If the fryer is too hot it will cut off the gas burner valve voltage:
OEM PN is 00-854453
Original PN VUL854453
Source 1
http://www.3wire.com/webstore/parts/PartSearchResults.aspx?searchText=Switch+High+Limit&mfrCode=VULCAN
$98.50
Source 2 Must log in.. new account
http://www.a1service.com/vulcan/vulcanlimit.htm
$90.20
The 854453 number comes up often in the part search for the high limit.
The high limit contacts can be checked and reading the NO and NC terminals. This control / switch is normally closed until opened by heat at 450 Deg F.
Thanks for Choosing FixYa,
Kelly
Sep 28, 2010 | Vulcan GRD45 Deep Fryer
Burner will not light
What you need to do is simple. Check for continuity between the following links diagram and any open parts are gonna be the problem. The main suspect is gonna be the gas valve solenoid followed by the control thermostat. if the fryer got real freaking hot then check the fuse and high limit that is tied into the gas safety magnet.
anybody with any fryer experience can fix that puppy in a minute.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 29, 2009 | Imperial IFS40 Deep Fryer
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
The fryer was working normal. Then the temperature light went out and the fyer is not coming on whe I flip the off an on switch
The first thing you need to check for is a high temperature limit cutout switch. It will be located near the gas valve but on the right side it wil have a cover that will snap open. it is about the size of 4" X 1 1/2". Once you get it open puch the button in you shoul dhere a click. When you hear the click you are reset. Once you turn the fryer back on use a temp probe or a type K thermocouple w/ a meter to check temp. if it starts over riding temp shut the unit off and replace the t-stat and the t/l cutout switch.
Thanks
Jul 20, 2008 | Garland AF-5025 Deep Fryer
Wells f49 fryer temperature problem
This is the cause of a faulty thermostat. You may also want to consider replacing the high limit as well if it has tripped more than a few times.
Jun 23, 2008 | Kitchen Appliances - Others
Wells 35lbs fryer double vat
Hello
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Thanks
Mar 29, 2008 | Wells F-686 Deep Fryer
Frequent tripping of the hight limit switch
Sep 12, 2007 | Wells F-49 21148 Deep Fryer
Wells F-49 21148 Deep Fryer Logo
120 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
