Question about Tablets & eReaders
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
Want to get the best life of the battery
Posted by hsmax on
Josh Meehan
    New Friend:
  • 3 Answers
You can go ahead and charge it to 100%. Maintain it by topping it off periodically. Try to avoid a complete discharge, but if this does occur, simply recharge at your earliest convenience. Each drain reduces the maximum capacity of the battery a little bit.
There are many variables that effect battery life, aside from the battery itself, it can seem quite overwhelming. Here is a table with some good information. The last column, Lithium-ion, is the battery type commonly used in cell phones and tablets. Please consult the documentation that came with your device to confirm this is indeed the case.
Frequently
asked question Lead acid
(Sealed, flooded) Nickel-based
(NiCd and NiMH) Lithium-ion
(Li-ion, polymer) How should I prepare a new battery? Battery comes fully charged. Apply topping charge Charge 14-16h. Priming may be needed Apply a topping before use. No priming needed Can I damage
a battery with incorrect use? Yes, do not store partially charged, keep fully charged Battery is robust and the performance will improve with use Keep some charge. Low charge can turn off protection circuit Do I need to apply a full charge? Yes, partial charge causes sulfation, Partial charge is fine Partial charge better than a full charge Can I disrupt a charge cycle? Yes, partial charge causes no harm Interruptions can cause heat buildup Partial charge
causes no harm Should I use up
all battery energy before charging? No, deep discharge wears battery down. Charge more often Apply scheduled discharges only to prevent memory Deep discharge wears the battery down Do I have to worry about "memory"? No, there is no memory Discharge NiCd every 1-3 months No memory How do I calibrate a "smart" battery? Not applicable Apply discharge/charge when the fuel gauge gets inaccurate. Repeat every 1-3 months Can I charge with the device on? Some UPS systems simultaneous charge and deliver current. It's best to turn the device off during charge; parasitic load can alter full-charge detection and overcharge battery or cause mini-cycles Must I remove the battery when full? Depends on charger; needs correct float V Remove after a few days in charger Not necessary; charger turns off How do I store
my battery? Keep cells above 2.10V, charge
every 6 months Store in cool place;
a total discharge causes no harm Store in cool place partially charged, do not fully drain Is the battery allowed to heat up during charge? Battery may get lukewarm towards the end of charge Battery gets warm but must cool down on ready Battery may get lukewarm towards the end of charge How do I charge when cold? Slow charge (0.1): 0-45°C (32-113°F)
Fast charge (0.5-1C): 5-45°C (41-113°F) Do not charge
below freezing Can I charge at hot temperatures? Above 25°C, lower threshold by 3mV/°C Battery will not fully charge when hot Do not charge
above 50°C (122°F) What should I know about chargers? Charger should float at 2.25-2.30V/cell when ready Battery should not get too hot; should include temp sensor Battery must stay cool; no trickle charge when ready Table 1: Best charging methods. Strenuous demands cannot always be prevented.
http://batteryuniversity.com/
http://www.techrepublic.com/blog/tablets-in-the-enterprise/how-and-when-to-charge-your-tablet-battery/
Posted on Feb 12, 2015
Leonard Goldstein
    Sniper:
  • 86 Answers
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
My tablet will not power up. I have charged it over night and still nothing. I tried different chargers and still nothing. Help!!
It could be that you have damaged the on/off button.
It could be that you have damaged the USB charging port.
OR
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Apr 26, 2015 | Tablets & eReaders
Went to use it and it won't come on. Thought battery might be dead and plugged it in and it still won't come on.
Mar 11, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
My pendo wont fully charge, and now it won't come on at all
Feb 23, 2015 | Tablets & eReaders
My tablet will not power on & shows no signs of charging
Feb 22, 2015 | Tablets & eReaders
Our son got the Digiland Tablet for Christmas, there were times when it would just power down. Now it won't come back on at all. Is this something that happens often? Can it be fixed?
Feb 03, 2015 | Tablets & eReaders
My kindle of two years old battery will only charge to half full, is that normal and can I replace the battery
Places like Batteries + are able to replace some tablet batteries.
Jan 20, 2015 | Amazon Kindle Fire HD
My sons rca 10.1 tablet wont power up.....right before this happened it was froze on the start up screen and wouldnt power off. I let the power run down hoping then I could charge it and it would power up...
Jan 19, 2015 | Tablets & eReaders
Kobo not accepting a charge
Jul 28, 2014 | Kobo Arc
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
Jun 07, 2014 | Tablets & eReaders
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
used up.
Jun 05, 2014 | Tablets & eReaders
Tablets & eReaders Logo
318 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
