Question about Garmin nuvi GPS
My Garmin Nuvi 310T dropping incoming calls on Samsung U600
My Garmin Nuvi 310T allows me to make outgoing calls over bluetooth using my Samsung U600 phone but when an incoming call comes it it rings once and drops connection. I am using the latest garmin bluetooth firmware, is there a way to revert to an earlier bluetooth revision on the Nuvi 310T?
Posted by dermot_mcnam on
5 Related Answers
Anonymous
SOURCE: bluetooth will not enable
I tryed every thin in this post none work for me, so I did try Garmin web site and I found the solution go to http://www8.garmin.com/support/download_details.jsp?id=931
connect your gps to your computer and run the software the select almost all the upgrade available and the languages I want.
affter done disconnect the nuvi 660, It will reboot by it self.
This Solve the problem with the screen freezes " enabling bluetooth" hope It work for you good luck.
Posted on Jan 10, 2008
Anonymous
SOURCE: Garmin 760 - No Voice Directions
Check The system settings, I had to download the newest version of the audio software for the voice to work. The software vanished once and I had to re-download it using the web updater.
Hopefully it will stick around this time.
When I load the new software the voice works.
Posted on Oct 20, 2008
Anonymous
SOURCE: garmin 760 is stuck on enabling bluetooth
Call Garmin tech support (US Toll Free: 1-800-800-1020 - Monday - Friday: 8 am - 7 pm) and tell them your Nuvi is freezing on the "enabling bluetooth" screnn, and that you need the latest .GCD file.
They'll email you a file: 006B055301.GCD with the following directions:
If you have a unit where the Bluetooth is disabled and when you attempt to enable it gets stuck on the “Enabling Bluetooth” message please follow the steps below.
1) Connect the Nuvi to your computer.
2) Find you’re My Computer icon and double click on it or you may find it in you Start menu and click on it.
3) Double click on the Nuvi() drive listed under devices with removable storage.
4) Double click on the Garmin folder.
5) Double click RemoteSW folder.
6) Copy and paste the attached file into the folder.
7) Close out the folder and safely disconnect the Nuvi from the computer.
After you have completed this, the Nuvi should be working normally.
I used WebUpdater to put the newest firmware on my unit before I did the above steps. Immediately after I rebooted, the unit automatically updated the bluetooth software on its own (however that might have been a left over from me trying to do it via the bluetooth reset menu you get to by pressing the speedometer icon for ~5 secs).
Everything works great now!!
Posted on Jan 27, 2009
Anonymous
  • 3 Answers
SOURCE: I dropped my garmin nuvi 760, it turns on, screen image looks like there is a "hole
This is for a Garmin Nuvi 760:
(From what you said, it sounds like you need a LCD+touch-screen combo)
First, you can find a new touch screen on E-bay for about 10-20 dollars. The LCD+touch screens are about 60. If you just cracked the screen but the display looks fine, you can just replace the touch screen.
Now, for do-it-yourselfers. To open the back of the case, there are 2 small torx (star) screws on the back to remove. If you don't have a torx driver, sometimes just the right size eye-glass screwdriver can fit but be careful not to strip the heads. Once those are out, you need to seperate the back casing from the front. I used an old credit card to pry gently with all the way around until it pops off. Don't force it, just be patient, it will come off.
Next, I recommend unplugging the speaker and battery so you can put the back aside for more room. There are 4 more phillips screws on all 4 corners of the circuit board. Take those out and the board comes out relatively easy. Don't force it. Once it is loose, there isn't much room to play with because of the ribbon cables. The large one is the LCD, the 4 pronged one is the touch-screen. There is a lever that lifts up and secures them in place. I got away with leaving them connected, but they are fragile and easy to tear. Next is separating the silver plastic part of the case from the black front that goes around the screen. I pried a bit with an eye-glass screwdriver around the area where the earphone jack and memory card go in. Again, using a credit card to pry all the way around is best that it won't leave scratches. Don't force it, just be patient.
Once you have that off, remove the screen from the case. I did it by pushing with light-moderate pressure all around the edges massaging it out. The touch screen and LCD have a rubber/leathery thin tape going around the perimeter. On the front, I got under it with an eye-glass flat head screw driver and slowly worked it around until it was free, being careful not to tear it. On the back, I used a razor-blade to un-stick it from the LCD, but be very careful not to damage the LCD screen if it's still working. The goal is to get this off in one piece. Once you have that off, there is the LCD and touch screen with double-back sticky black tape holding them together around the edges. I used a razor-blade. VERY CAREFULLLY separating them. Once that was done, I carefully scraped the remainder of the tape off the LCD which was un-reusable. I didn't know what to use for putting the new screen on since I didn't have that special type of tape, so after raiding my tools, I found some rolled butyl rubber for installing windshields. I cut small pieces of this off and put them around the perimeter of the new touch-screen (VERY THIN) in the same place the old one was, as if I was installing a real windshield. This took much patience, but in the end it worked great. Before putting the new touch-screen on the LCD, I blew it off with some compressed air, being careful to never leave a fingerprint on it while working on it. After putting it on, I pressed softly but steadily to get the rubber to even out so there wasn't any high points. Then, I replaced the same sticky tape that went around the perimeter of the 2 screens the way it was. It wasn't as sticky, but I made sure it was in place and it kept there by the pressure on the sides of the screen casing. Make sure you get it on right, because I think it's there as a shock-absorber so that the screen doesn't break as easily if dropped or jarred. I plugged back in the LCD screen into it's corresponding place on the circuit board and closed the tiny lever that secures it in place. Then comes putting everything back the way it was in reverse order. Be careful and go slowly, I ended up accidently pulling the ribbon cable out for the LCD and Touch screen and had to go back and reconnect them. This is a good time to attach the battery and turn the GPS on to see if you have all your connections made securely before everything is fully together. Put everything back together in reverse order, remember, if you have to force it, then don't. Don't forget to hook the speaker back up.
When it's all back together, if the new touch-screen doesn't tap where you tap it, you can calibrate it. This can be done by turning the unit off, then turning it on, then IMMEDIATELY switch it to the right(lock) position before it boots up and hold your thumb on the screen for about 30 seconds. There will be a callibration routine that will tell you to push dots on certain parts of the screen. If you do this with a stylus, it will probably be more accurate.
Now hopefully, you will be more careful and not drop your nuvi again. I hope this helps.
Posted on Sep 05, 2009
Anonymous
  • 502 Answers
SOURCE: my garmin nuvi 310T will
Most likely a defective dc-jack or battery. Sometimes it's a broken logic board too. If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
Posted on Jul 15, 2010
2helpful
How to pair a iPAQ 214 with an external GPS receiver?
It's pretty easy.
In your iPAQ 214 go on SETTINGS > GPS > and make sure the INCOMING CONNECTIONS are on CHANNEL 6, and for the OUTGOING CONNECTIONS are on CHANNEL 5.
Start the external GPS device, start your Bluetooth connection on your iPAQ and you're ready to go.
My samsung s5233 tuch screen phone show 'service not allowed' during outgoing calls but it can receive incoming calls.
In the settings menu, you are able to disable the ability to make outgoing calls. You will need the security code for the phone in order to change this.
2answers
No contacts on GPS from Nokia E71
You may have to allow access from your bluetooth to your phone via your buetooth menu on you garmin. I know I did that with my mortorla phone and garmin. I hope this helps. If not I will try to get mine to work. I use a motorola blue tooth car speaker it has better noise canceling and reception.
1helpful
Cannot connect my samsung phone to garmin gps using bluetooth The phone is a Samsung SGH-T456 and the Garmin GPS is a 265WT. They can sync to each other but the Garmin does not show the answer screen when...
there are a few phones that garmins dont work with try software updat from www.garmin.com and samsung, if not that connact garmin and ask if they know of this problem
Dec 27, 2009 • GPS
My garmin nuvi 310T will not power up
2answers
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
1helpful
2answers
Samsung u600 restart problem
Ok try a full reset *2767*3855# make sure your phone is fully charged and dont remove the bad while in process wait for it to come back on.
2answers
My Samsung sgh u600 incoming calls go straight to voicemail
Check to see if you have any of the of the 'call diverting' features turned on...
Menu
7 (network)
Check call diverting and call barring are NOT active.
2helpful
My samsung u600 turns on but has nothing on the screen whats up?
Are other functions normal? I mean outgoing and incoming calls?
May 19, 2008 • Cell Phones
2helpful
5answers
Samsung U 600 failing to connect to blue tooth conection
i have purchase a phone with a bluetooth that comes with it. the bluetooth would only light up while it is charging and blue when it is ready. but it will not turn on at all. please help me solve this problem or give me info of where to call. thanks. lucy
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
