You can request a password reset. Go to https://www.paypal.com. Click the ? in the password box and follow the prompts. You cannot retrieve your present password but must go through the process of setting a new password. Check your email Inbox for the confirmation email to start the process.
If you cannot access with the new password, have you tried the old one? Sometimes the new one doesn't take correctly. also, since most passwords do not display when changed, and even assuming you had to enter it twice to confirm, check to be sure that you didn't enter it with CAPSLOCK on. Passwords are usually case-sensitive.
Not sure if you got this sorted, but all i did as i couldn't remember my pasword and could only login using fingerprint
go to
Start
type 'CMD'
Right Click and select run as administrator
In the command window type NET USER XXXXX welcome01
Where XXXXXX is your user Name
This will force the change of password, and doesnt mess with Verisoft. Now to confirm it's worked go to
Start
Control Panel
Users
Select Change password
in old password type 'welcome01'
in new type which ever you require as your password, it will accept the change.
If you forgot your password click here ..........forgot password
If you have confirmation code click here .......have confirmation password already Look for the confirmation code from the inbox of your mail account. If you can't find it in there, look for it in the spam.... Wait also in your phone if you want the confirmation code to be sent on your phone.
Please accept this solution if this help you. Thanks
To change the password: 1 Click Password in the left column. The Password screen opens. 2 In the New Password field, type the new password (up to 9 alphanumeric characters). 3 In the Verify Password field, type the same password to confirm your change. 4 Click Save to accept your Password change or Cancel to remove your entry and return to the default setting.
Facebook has settings it uses (that YOU set it up with) to confirm any changes to your account.
Any time you change something on Facebook, it will confirm that YOU are the proper owner of the account by sending a CONFIRM email to (the email address you set it up with.) You would need to CONFIRM this email (your old email address?) before any changes take place.
If you changed your email you should have registered this change in your Facebook account settings FIRST.
Try logging in to Facebook with your old account settings (email/password), then go straight to changing your default email contact address (this is not effective until it receives a REPLY from this NEW email account, so it can verify that the NEW account is actually valid.)
THEN Facebook will have finalized your change.
Your question is not clear...but if you want to change your yahoo ID's password just follow this link or login with your Yahoo ID and Password....go to your mail page...then click on your ID the pop down window will show a list ...click Account Info ...it will redirect you to a page asking to confirm your password...once you typed correct password click sign in you will see the Account information page..then see below there is the option to change the password....Thats all...Thanks for being with Fixya...Good Luck
There is usually a way they can resend the password to your mail with a new password for you to re-login and change to new password. You might also consider calling customer care.
BW
