Look between roof & base of AC unit for little round button like pieces sticking down, which are drains, that have holes in sides that get plugged up. poking with a piece of wire or similar in that hole may unplug it. You should see at least 2. Depending on what type of AC unit, it may just be holes in base for drainage, but if necessary to unplug, you can easily remove cover. Coleman has 4 big Philips screws on top to remove & dometic has a bunch of Philips screws around lower edge to remove & cover will come off, to check where plugged. Make sure power is off inside.(breaker) You should see a trail of water across roof from AC when running & cooling, if not plugged. There is the posibility of a cracked drainage tray allowing water to leak inside as well on some of the older models. You should be able to inspect all of that when cover is off on roof. P.S. CAREFUL! Observe before lifting cover off for wasps in the area, as not unusual for them to make nests under cover. Be prepared, or do on cloudy day, early in the morning, or near sundown when less active. Also, if dew on roof, could be slippery.
