Most of the newer phones have a feature that quiets the ringtone when you touch the phone or move it. You can deactivate this feature in the settings menu. I hopes this helps you..
To extend the number of rings before your phone goes into the answer message option, change the settings for Answer delay option as described below.
You can set number of rings before your phone answer message kicks in. You can set answer message to begin after 2, 4, 6 or 8 rings.
1. Press <Menu> and up down to select ANS Machine
2. Press <OK> and <up/down> to select TAM Settings
3. Press <OK> and <up/down> to select ANSWER DELAY (OPTIONS: 2, 4, 6 OR 8 RINGS)
4. Press <OK> and <up/down> to select to select desired delay.
5. Press <OK> to confirm.
I believe that the redirect call service was activated and remain active ..or the phone is on silent mode and this cause it being redirected after a number of calls .(this is correct only if the mobile starts ringing after a few rings ...check it ..cause if it starts right the way it means it is redirected from start ..) ..To avoid all these I suggest to look in the setting menu of the phone ..and select to load default or factory setting s..This will make it loose the redirect settings ..or ...disconnect it ..and remove its batteries for a while ..and it eill also get to the factory settings ...remember this may need a reset for any settings it uses if it is an Ip p[hone and not a direct plug and play device ..
how do i extend the rings that my eurotel e1110/e1115 phone makes before it rings off , at the moment it rings 3 times and i never get there before it goes to answer phone
Hi don't know if anyone still needs this info, or indeed if it's right for your phone. To toggle the lock on our Binatone keypad, you just hold down the red-orange call-hang-up button for a couple of seconds. I've also found another posting (for a different model) that advises holding down the hash key. Hope one of these helps.
