Is your TV connected to a Set Top Box (Cable TV box?).
If so, then you will get blank screen until that box is powered on. Secondly, you could check the cable (usually HDMI cable) between the SetTop Box and the TV..
A Blue Screen, means that there is NO signal be "Given" to the "Input" that the TV is currently using. Try another "Input" or check your antenna is OK, you are "ON" the right "Input" too.
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
If you're not getting the audio signal, please select the Audio for HDMI to TV+AMP in Menu display. If you're not getting the videos, please check if the TV is HD ready and supports 1080p signals. Also check if the connections are firm and secure and you selected the correct input on both Receiver and TV. Please try connect the Settop box to different HDMI port of the receiver and try. You can also try connecting the Set top box to tv directly and check if its working. If its working fine directly with the TV, you may try to replace the cable and try else the receiver may require service
hi friend, i too having the same tv BPL - 21 FCR, i have brought it from my relatives, and they lost their remote years back, and now i want to buy that remote, can u please tell me the remote model number which will be printed on your remote panel. especially on your remote only... plz help me, with this problem. thank you in advance... please send me the number to my email id [email protected]
