Compaq laptop keyboards have a variety of sizes and configurations to fit the design of the laptop itself like smaller laptops or larger laptops with full-size keys. You might now find that the keyboard or keypad exhibits problems such as sticking keys or general unresponsiveness from your owning Compaq Presario laptop because of several years'using. Besides, you have made sure that your old keyboad is clean but it still doesn't work well. Then you have to install a new one. So how to do it? Don't worry, you can DIY your Compaq new keyboard via this guide.
Step1. Exit Windows and turn off your computer.
Step2. Unplug the power cord and modem and network cables.
Step3. Place your laptop on a clean and disconnect the old keyboard. Open your laptop screen as far as you can.
If you are installing a USB keyboard, connect the keyboard to a USB port on the back of your computer.
Step4. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Compaq Keyboard in place.
Note: Keep these screws in a safe place.
Step5. Gently tug the Compaq Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
Step6. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right.
Step7. Connect the power on your laptop and verify that the new Compaq Keyboard is working.
OK, well done!
Compaq keyboards are inexpensive, easy to find and quick to install. Actually, all Compaq Presario laptops have reasonable prices and you don’t have to worry if something breaks down as replacements are easy to find and cheap to buy from Papatek. Papatek Compaq Laptop Keyboard are specifically designed for each Compaq laptop brand and model.
Take out the keyboard completely and reseat it. then turn on the power and see if you can use the keyboard, if you can then when you get into windows, enable the mousepad.
