Question about Konica Minolta MC1690MF Magicolor 1690MF Laser Multifunction Printer
I dont have the admin password for my Konica Minolta 1690MF. I have tried 12345678 and it didn't work. Is there something else I can try? How would I get it to reset to default?
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Konica minolta Di3510 Tech Password
if three times you tried with wrong password at saem time you have to change ram
Posted on Oct 02, 2008
Anonymous
SOURCE: Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Posted on Apr 02, 2009
Anonymous
  • 4 Answers
SOURCE: Konica Minolta Di 3010 - cannot clear trouble message
one thing you can try since you have already removed the fuser you can probably do this but i would not recommend it unless you are familiar and comfortable with the components of the machine turn the copier off remove the back cover you will see in the middle of the machine a metal cover with 4 or 5 screws, behind this cover is the main board it has many wires going to it through out the machine...remove the cover so u can see the board and all its connectors on the board there should be a little black button... turn the machine on press this button and the code should reset. If the code does not reset then the thermistor or thermostats are bad and the fuser needs to be rebuilt. as for the password 8 zeros or 1-8 are the defult passwords for the machine. you can also try 1247....
Posted on Apr 08, 2009
Anonymous
  • 167 Answers
SOURCE: I have a konica minolta magicolor 4650, that
ACK!
No.
You will need a Technician to format the machine to restore to defaults.
Posted on Apr 27, 2009
Anonymous
  • 214 Answers
SOURCE: need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 - now you are in service mode, - stop 0 C, and there shold be admin pwd
Posted on Oct 14, 2009
How to reset a password of bizhub 600-750
Which password the admin or the individual passwords Default admin 12345678 or 00000000
Go to:
Admin setting- Security setting -admin password
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 23, 2014 | Konica Minolta Bizhub 600 750 Image...
I forgot my Bizhub 223 administrator password
The admin password is 12345678 yes you can change the password you will need to log into the tech rep mode once in tech rep mode you need to press the following buttons stop 0, then the C button
once this is done you then select admin password and change it
Aug 04, 2014 | Konica Minolta Bizhub 223 Copier
HOW TO ADMIN PASSWORD
The admin password for Konica Minolta copiers is 12345678 or 00000000.
Apr 18, 2013 | Konica Minolta bizhub C250 All-In-One...
I brought a bizhub 420, how do i reset password
I had an older Minolta a couple of years ago. I'll try adapting what worked for it to this machine. Hopefully this will work.
Press the "utility" button. Then hit "admin settings". Enter a password of 12345678. Then hit "user authentication" and put in "off". Hit panel reset from the main menu.
Again, I'm not entirely sure this will work for the 420 but its worth a shot. Good luck!
Apr 26, 2012 | Office Equipment & Supplies
I have konica minolta bizhub pro c500 machine, that is password protected, I don't know the password. how can i reset password?
You dont specify what you want the password to. So here are some options to try.
If you want admin access to the Fiery print controller the default password is "Fiery.1"
The default operator password for a Creo server is "colorserver"
I'm not positive about the default admin password for the C500 but I'd try these.
eight zeros: "00000000"
or: "12345678"
If these don't work chances are someone has changed them from the default. On the Fiery or Creo this usually means a software reload. On the machine a service rep can probably reset the admin password.
Aug 29, 2010 | Computers & Internet
How can I rest the admin password on Bizhub c250
still having trouble..if default password didnt work for you then try reseting it to default password by:
1) Utility/Counter
2) Details
3) press STOP zero zero + STOP zero one
and now your in Tech Mode
4) same page press STOP + Zero + C
5) modify admin password and retype and then exit
6) do not DO NOT touch any other options unless you know what your doing..you can lock the machine and would be able to work..rate if this helped you out
Feb 24, 2010 | Konica Minolta bizhub C250 All-In-One...
Mar 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta MC1690MF Magicolor 1690MF Laser Multifunction Printer Logo
1,100 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
Tom Chichester
Terry
Terry
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
