Numbers and letters are in large. All I see on screen is 3 whole numbers 3 half numbers. ie, it is all enlarged
Try doing a hard boot by holding both the power and home (button on bottom/front of screen) at the same time for 8-10 seconds.
The phone should shut itself off all at once then boot back up.
You can let the buttons go after the power turns off.
SOURCE: Iphone Screen Freeze
try holding down at the same time both the round button at the bottom of the phone and the on-off switch at the top
this re-sets the phone and all should work again
SOURCE: Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "the last option helped alot thanks x"
SOURCE: I have enlarged icons on my screen
-Try a double-tap with 3 fingers on the screen
Turn behaviour off as follows:
- Go to Settings
- Go to General
- Accessibility
- Zoom
- Select OFF
SOURCE: my iphone 16GB has enlarged screen i.e zoomed
Another solution that doesn't involve turning off your Zoom feature, is to simply tap the screen two times with three fingers. See the solution at :
http://www.youtube.com/watch?v=KvcYZOiERaY
