Question about Carrier 52CE215 Cool Electric Heat Air Conditioner
Ptac unit wont cool
Cleaned only
Posted by tony on
Scott Leigh
    Scholar:
    New Friend:
  • 78 Answers
Check unit's ID#'s and add any hyphens, etc or separate letters, numbers, to be exactly what's on unit.
Inside sources might help. Popular Questions Answers Tips Manuals for Carrier 52CE215 Cool Electric...
Questions Answers for Carrier heating element
Posted on Feb 11, 2015
Runs louder after cleaned condenser unit
The filthy condenser unit was also acting as a sound absorber. Now that the "absorbant" has been cleaned ..........................
Aug 05, 2015 | Refrigerators
Won't start
Make sure you didn't miss a vacuum hose and that the petcock is in the on position
Mar 30, 2014 | 2011 Husqvarna WR250
Raptor 660 starting problem...new plug, new hoses, new oil, new radiator, rebuilt water pump, rebuilt thermostat, cleaned carb, cleaned all jets, cleaned petcock, cleaned fuel filter, turns over fine,...
Hey Josh,
Cleaning a carb is a little more that most people realize..it takes someone with knowledge and training to really do one right... take it to a professional..
Jun 23, 2017 | Yamaha 2010 Raptor 90
Ihave a 1986 honda shadow 500,starts but won't rev
make a compression test on 2 cylinders, http://www.youtube.com/watch?v=cdif7gaWDLc
May 07, 2012 | 1986 Honda VT 500 C Shadow
The dryer is completely cleaned but it shows it should be cleaned and will not start
check ur vent hose that goes out side it could be almost stopped up causeing it to billed enough psi to make the senser think that the filter is not cleaned
Feb 15, 2012 | Whirlpool Dryers
How often should the furnace should be checked and cleaned by a professional?
As suggested by manufacturers, a furnace must be cleaned every year.
May 03, 2009 | Goodman GMS90703BXA Heater
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
HP 6110xi -clear carriage jam
LOOK BEHIND THE CARRIAGE IS A SEE THROUGH CALIBRATED RIBBON WHICH NEED TO CLEANED, IF IT DOESN'T WORK THE SENSOR BEHIND THE CARRIAGE MUST BE CLEANED
Nov 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Heating & Cooling Logo
172 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
John Tripp
John Tripp
Ekse
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
