Kenmore 24032\24036 Top Load Washer Logo
A
Anonymous Posted on Feb 10, 2015
Capacity size of Kenmore Elite Heavy Duty Quiet Pak II # 20954994
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Sep 14, 2007
SOURCE: Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Anonymous
  • Posted on Jun 19, 2010
SOURCE: 22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
Anonymous
  • 5911 Answers
  • Posted on Aug 12, 2010
SOURCE: Kenmore 90 series heavy duty super capacity plus
If your TOP LOADING Whirlpool manufactured washer (Kenmore) is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Anonymous
  • 176 Answers
  • Posted on Sep 15, 2010
SOURCE: Kenmore 90 series Heavy Duty Super Capacity Plus
hi check the lid swetch
Anonymous
  • 15935 Answers
  • Posted on Sep 30, 2010
SOURCE: What capacity is a Kenmore Elite, king size, heavy
3.8 cu ft
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
9helpful
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
3answers
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
Alexander
vince
