2006 Chevrolet Malibu Logo
A
Anonymous Posted on Feb 10, 2015
Fuse to open the luggage lid for 2006 Chevrolet Malibu LS
I looking for the fuse to open rear lid
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 2,226 Answers
  • Posted on Feb 12, 2015
James Miller
Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447497
Points
2985
Http://www.autofuseboxdiagram.com/14088-2006-chevrolet-malibu-fuse-box-diagram/
frontier98
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Feb 11, 2015
frontier98
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
3106
Points
7
The power block that includes the fuse and power relay for the power trunk lid are located inside the trunk. After you have opened the trunk lid (using a key), look at the left wall to locate the access flap that is cut into the trunk lining. The fuse block is underneath this flap. The 10 amp mini fuse for the power trunk lid is at location #22 and the mini power relay is at location #36. Check the schematic on the fuse block cover for exact locations.
Where is the fuse for my driver seat? Does it operate both seats
Fuse Block - Rear
Left side of the luggage compartment, behind the left rear wheel well
.1
PSG SEAT Fuse -
30A
Seat Adjuster Switch - Passenger
DRV SEAT Fuse
30A
Seat Adjuster Switch - Driver
What fuse number is the abs fuse on a 2006 trailblazer
it should say on the cover lid for the fuses ,what each one is/.if not go on line and look up fuse box diagram.
The outlet fuse in 2006 chevy malibu ls.
In the under hood fuse and relay center.
What fuse box is my lighter fuse in 2005 chevy malibu classic
The cigarette lighter fuse on your 2005 Chevy Malibu Classic is located at the rear end of the car. To access it, pop open the trunk and look for a fuse box on the driver side of the vehicle - it'll be under a carpeted cover. Remove the cover, then the lid of the fuse box, and you will find your lighter fluid in the middle on the bottom row.
4helpful
Where is the fuse location for the cigarette lighter for 2008 chev malibu?
{: ) hi! Check out the rear fuse block which is on the left side of the luggage compartment, behind the left rear wheel well. Look for fuse labeled CIG/AUX 20amps.
4helpful
2answers
2006 chev malibu fuses where are they automatic mirror adj, cig lighter and right rear tailight (Break)
theres a fuse box under the rear driver side tail light, open the trunk theres a small space to for storage, look underneath it u'll see a "door" open then look for a black box. it flips down, it has ur basic fuse, tail lights, **** like that, all other major ones like horn are under the hood between the driver fender and the battery
4helpful
3answers
The front cigarett lighters do not work on my 2006 Chevy Malibu Maxx. What fuse do I need to change to fix this?
There is a fuse box located in the trunk on the drivers side. Remove the panel and the fuse is #20..also a 20 AMP fuse.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
