Question about Maytag Washing Machines
Washer error F06 E01
The cycle donot start. It counts down for 3 min. The Error E01 and F06 comes up
Posted by Chantel Charles on
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
Anonymous
  • 7 Answers
SOURCE: samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
Posted on Jun 23, 2008
JR JR
Johnny Ramirez
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
Anonymous
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Posted on May 18, 2009
Anonymous
  • 232 Answers
SOURCE: Kenmore Elite quietpak9 HE4T washer FH error code
go 2 repair clinic on line, same codes for whirlpool duet repair help then error code tab
Posted on Dec 24, 2009
What is causing error codes F06 E01?
This error message means an electronic communications problem. Press pause/cancel twice to cancel the error and then disconnect the power cord from the outlet, wait few minutes, plug the power cord back in and select a new wash cycle.
If you see the same error again then you need to check the connections located between the drive motor and motor control unit.
My whirlpool duet washer has error codes, F06, E01 and int. how can I reset the washer?
The Electrically Erasable Programmable Read-Only Memory (EEPROM) on the main electronic control board is corrupted. Unplug the washer for 5 minutes, restore power and see if the code clears. If not, the replace the main electronic control board.
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
What does Error code F06 mean
Try this:
Possible Causes / Procedure1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Read more: http://forum.appliancepartspros.com/washer-repair/11384-front-load-maytag-what-error-code-f06.html#ixzz33vFGkt1n
Error code F06 and E01
Here is what the F06 code stands for
Drive Motor Tachometer Error
Potential Causes
(CCU)
• Check the MCU
3helpful
2answers
My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
1helpful
I have a kenmore elite 3 that flashes f06
"F06" is a Motor Speed error code. This could indicate a problem with the drive motor, motor control unit (MCU), interconnecting wiring, or the tachometer (part of the MCU). The following link explains:
I would begin by checking all the wiring and connector plugs between the MCU and drive motor. Vibration from the washer can cause the connectors to come loose. Also check them for any signs of corrosion that may be causing poor contact.
Measure the motor windings to see if they are still within specs. Bad motor windings could generate the error code as well.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Neer the end of the cycle (last 6 min or so), it stops, beeps F06
"F06" is a Motor Speed error. The following link explains how t troubleshoot:
Let me know if you have any questions. I hope this helps you.
1helpful
E-43 still after a new control board
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin lights should light. Any error codes should be displayed when holding those keys.
Washing Machines Logo
Top Maytag Washing Machines Experts
Jessie Goss
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
