Question about Vector 1 Million Rechargeable Spotlight
Why does the garrity spotlight red charging light only come on when the on trigger is depressed?
I have a garrity spotlight. The red charge light does not light up when the ac adapter is plugged into the outlet and spotlight. The red charging light does come on when the ac adapter is plugged into the outlet and in the spotlight and the on trigger is depressed. The battery will not charge.
Posted by Joe varda on
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Posted on Jul 01, 2008
Anonymous
  • 555 Answers
SOURCE: Strange ac cord/power issues
Hello my friend, Try to check your battery if the is it working normal cause sometimes the battery itself has the problem its either lost contact or the battery is not charging or not normal. also try to see if the the the sensor or that links the battery to the software which is responsible to the update of charging energy is functioning normal but this is a rare possibility try to focus on the battery or the connector or power cord.
Hope this will able to help solve you problem. If you need more assistance just reply to this post. Thank you
Jonas
Posted on Jul 09, 2009
Anonymous
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
IQUIT
  • 3940 Answers
SOURCE: i had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Posted on Sep 26, 2009
Testimonial: "thanks for the prompt response."
Suresh Ayyar
  • 1481 Answers
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
Posted on Dec 29, 2009
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
Spotlight will not charge
It seems like the charging circuit inside the light may be bad, contact Coleman to have the light repaired.
Jun 15, 2010 | Boating
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Vector 1 Million Rechargeable Spotlight Logo
494 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
