Question about Honeywell RTH8580WF WiFi Thermostat
Have a Wi-Fi touchscreen programmable thermostat. The fan will not come on in the auto setting, it will only works in the on setting
HVAC guy was here trying to figure out why the furnace was only blowing cold air. We have warm air, but the fan will only work in the on setting
Is there also an on/off switch for the fan on the furnace itself? If so check it make sure its set to on. Also check the on/off contacts of the switch on the t/stat to make sure its working.
Posted on Feb 18, 2015
2 Suggested Answers
6ya staff
SOURCE:
  • 6065 Answers
SOURCE: thermostat won't keep furnace fan running
You probably have a loose or broken wire to the fan relay. Check the wires on the thermostat first. Pull up on the bottom of the thermostat to remove it from the wall plate. You should see several screw terminals and the conductor wires that should be connected to them when you look at the wall plate. Check if any of the wires are disconnected or broken. If a wire is broken, strip a portion of the unbroken section of the wire and secure it to the appropriate screw. (The fan relay terminal is G for most setups.) If none of the wires are loose or broken, then you have to check for damage to the wires between your heating system and the thermostat or at the heating system. It could be a bad wire going to the jumper on control board or damage to the board itself.
I hope this helps. If the problem is not at the thermostat, you may need to have a professional diagnose and fix the problem. However, if you post additional comments about your heating system, Fixya experts may be able to help you diagnose the problem.
(we had the broken wires at the thermostat keeping the fan from working in the past. It's an easy fix if you are willing to handle small wires carefully.)
Posted on Jul 06, 2013
Having trouble with a wi fi connection from my cgo2 camera to my galaxy 7 phone.it will connect sometimes but not every time.anything i can do to get a reliable connection every time?
camera distance may be too far from wi fi source ie router or access point ? possible solution use a wi fi range extender.
Neighbours Wi Fi interfering with your WI FI . possible solution change the channel used by your wi fi from auto to channel 3 or channel 6 . This ensures channel spacing from neighbors if they are on auto as well . Setting in wi fi access point or wi fi router
Jun 12, 2018 | Galaxy Cell Phones
Is the th8320u 1008 thermostat PROGRAMMABLE?
Yes the Honeywell TH8320U1008 touchscreen thermostat is programmable. See https://customer.honeywell.com/en-US/pages/product.aspx?cat=HonECC+Catalog&pid=TH8320u1008/U for the operator's manual. Click on the Literature tab and scroll down to the Owners Manual section. If your thermostat isn't working, make sure that it is set for heating or cooling, as needed. Then check the batteries, the wiring and the HVAC system. (The thermostat has a default set of heating/cooling periods.)
It's not uncommon for one of the wires going to the thermostat to break. Find the undamaged section of that wire and secure it under the appropriate contact spot. Make sure all of the wires are positioned at the correct contacts.
I hope this helps.
May 18, 2018 | Heating & Cooling
I have a different home wi fi router how do i reconnect my wi fi thermostat sing-in
Press Fan & up arrow @ the same time until you get into programming mode. download the manual & go through the numbered steps until you get to the turn wifi on & off. When you turn it on, it should show up on your computer wifi list. then program the wifi the same way you did initially with the other router.
Jun 05, 2016 | Honeywell RTH6580WF Wi-Fi Thermostat
My zte lever won't hook up to my home Internet.. Please help
This tutorial will explain how to get connected to Wi-Fi on your ZTE Tania Connecting your phone to a Wi-Fi network means you can access the internet, download apps and perform other tasks without incurring data charges.
This guide will show you how to get connected on the ZTE Tania.
How to connect to a Wi-Fi network
  1. From the main menu either swipe right-to-left on the touchscreen or press the right arrow button on the top right of the interface.
  2. Scroll through the menu and find the 'Settings' icon, then tap it.
  3. Press the button marked 'Wi-Fi'.
  4. Tap the Wi-Fi networking On/Off switch to turn Wi-Fi on.You'll then see a list of available wireless networks.
  5. Select the network you want to connect to.
  • If you selected an open network, your phone will automatically connect to the network. Note that some Wi-Fi networks, such as ones you might find in coffee shops, restaurants, or hotels, may require you to enter a password in your web browser before you can connect.
  • If you selected a secured network a password box will pop up. Enter the required password and then press 'Done'.
When you're connected to a wireless network, the wedge-shaped Wi-Fi connected icon appears in the status bar and shows you the signal strength - indicated by the number of bands that light up.
Unless you have wiped your phone, you won't be required to re-enter Wi-Fi details again as your handset should remember them.
How to connect to hidden networksA Wi-Fi network might be hidden, which means the network name isn't broadcasted. In this case, it won't appear in the list of available networks on the Wi-Fi Settings screen and a notification won't appear when the network is in range.
To connect to a hidden Wi-Fi network when it's in range, you'll need to enter the network name and password. Remember that the network name and password are case sensitive.
  4. Ensure that Wi-Fi is switched on.
  5. Press the 'Advanced' button.
  6. Tap the plus (+) icon.
  7. Enter the network name.
  8. Press the 'Add' button.
  9. On the 'Sign In' screen, enter the password, then tap 'Done'.
How to disconnect from a Wi-Fi network
  4. Tap the Wi-Fi Networking On/Off switch to turn Wi-Fi off and disconnect from the wireless network.
Alternatively, you can also press and hold the network name and then tap 'Delete' to disconnect.
However, bear in mind this removes the security settings if it's a secured network, meaning you'll need to enter them again next time you reconnect to that Wi-Fi network.
http://www.knowyourmobile.com/products/15952/guide-how-connect-wi-fi-zte-tania
Apr 05, 2016 | ZTE Cell Phones
I am unable to connect to the Internet even though the email address and password are accurate. This just happened.
Trouble Shooting - - FAQs ' FWD - Honeywell
lyric.honeywell.com/support/troubleshooting/
How do I delete that thermostat from my Lyric app? If you've moved and ... How do I change the email address I use to manage my Lyric? If you already have a ...Missing: programmable ‎accurate
Wi-Fi 7-Day Programmable Thermostat ' Honeywell
yourhome.honeywell.com/.../thermostat/wi-fi-7-day-program...
HoneywellThe Wi-Fi 7-Day Programmable Thermostat is designed for the way you live ...Features such as Smart Response and precision temperature accuracy bring ... your home heating and cooling system, and then remove your existing thermostat. .... Whileconnecting to Wi-Fi, my model RTH6580WF or TH6320WF thermostat is ...
FAQs - Total Connect Comfort
Dec 29, 2015 | Honeywell Programmable Thermostat Heater
Wii-fi will not turn on
Let me know the device you are using
Jul 13, 2015 | Google Android
Can't set clock
Hello Dan, I found this online and thought you may be interested in taking a look at it. Here's the website address and hope it's informational. http://yourhome.honeywell.com/home/Products/Thermostats/7-Day-Programmable/RTH6580WF.htm
If this doesn't solve the problem, you might have a defective thermostat.
Mar 08, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
My coby/kyros is not picking up the internet with wi fi
Some devices need the Wi-Fi service turned on/enabled. Please check your devices settings to be sure that Wi-Fi is "On"!
Dec 06, 2011 | Coby Kyros 7" Touchscreen Tablet
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Honeywell RTH8580WF WiFi Thermostat Logo
234 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
