Question about Water Water Heaters
Cant find atwood control for water heater [modle #37c14u-5 atwood#mpd 91403
I can lite heater ok ,pilot ok,heater ok, burns for awhile then goes off.also pilot goes off.
Posted by jack hart on
Lawrence Oravetz
  • Water Master
  • 10,548 Answers
Get a new thermocouple for the pilot light.
Posted on Jun 10, 2016
5 Related Answers
Bill Johnson
  • 306 Answers
SOURCE: I have a 6 gal Atwood hot water heater. I can
Kenny did you change the thermo coupler?
Posted on Jul 14, 2009
Anonymous
  • 160 Answers
SOURCE: The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Posted on Jan 09, 2010
motor1258
Mike Butler
  • 6674 Answers
SOURCE: I have an Atwood 6gal hot water heater with a
Try removing the thermocouple where it attaches to gas control, and spray a little WD-40 in the hole, then spin a rolled up small piece of steel wool in the hole as well, then blow it out with compressed air if you can. Then reconnect thermocouple. Make sure thermocouple tip is getting good flame under it, and if that doesn't cure it, then it's time to replace gas control.
Posted on Jun 24, 2010
Anonymous
SOURCE: I have a Jayco pop
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Posted on Jun 28, 2011
WallyWorld
  • 6 Answers
SOURCE: will this solve my problem of the pilot going out after the water is hot?
Your thermo coupler may be going out. If the thermo couple does not sense heat it will shut the gas off. This is a safety feature. Once you replace that you should be ok.
Posted on Aug 14, 2012
Where can i buy 37c14u-5 gas valve
If its for an rv water heater as stated above ( Atwood) any rv dealer should stock them.
Feb 08, 2013 | RTO Atwood Water Heater - 6 Gal LP
Will this solve my problem of the pilot going out after the water is hot?
Aug 14, 2012 | Camco 08773 Gas Pilot Assembly 9 Inch for...
I need to know the part number for the thermocouple on an Atwoods mpd 91043 water heater
For a straight, manual ignition, atwood kit #A91603 give's you a new pilot and thermocouple assy. Approx. $30-$35.
Sep 08, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
More resources:
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Hi, I have a Atwood 91043 (Model 37C14U-5). The pilot and main burner seem to work fine (main burner ran a couple minutes then shut down) but I'm not getting hot water at the facet. I have the...
Have you checked back of water heater for proper valve positioning? (by-pass may be on)
Cold water enters through bottom fitting and hot comes out the top. Any valves in between should be closed and any valves going in bottom and out top should be open.
Jun 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a 6 gal water heater i lite the pilot and turn to on and it runs for awhile then just shuts off
It could be a couple of things, the thermocouple may have gone bad or the actual control has died. I assume that the gas valves are open and in case of propane you have fuel in the tank. water heaters last 5-10 years so replacing the control on a older unit is not cost effective however thermocouples don't cost much.
Jun 28, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood 6gal hot water heater with a 37c14u-5 controller. The pilot light will not stay lit. I have replaced the thermal coupler twice and the pilot tube with orfice once. It's still not...
Jun 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
411 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
