Lionel The Polar Express Train Set Logo
Question about Lionel The Polar Express Train Set
Led blinks when train put on track
Led stays steady until the train is put on track , then it blinks and won't run
Posted by Steve Braun on
Gerald Lewis
    New Friend:
  • 34 Answers
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Posted on Feb 10, 2015
Testimonial: "If I only put a passenger car on tracks it does same thing ? Lights on car blink on and off and also led blinks . It's brand new out of box today . Does it need to charge ?"
  • 4 more comments
  • Gerald Lewis Feb 10, 2015
    This sounds like an issue with the power supply regulator board. Put the passanger car back on the tracks and connect the rail power to the accessory output of the transformer. Make sure you follow the instructions to set the accessory outlet power to at least 10VAC. If the light in the passanger car stays on, the problem is with the rail power regulator board in the CW80.
  • Steve Braun
    Steve Braun Feb 10, 2015
    This is a polar express ready to run train 78-1101-250 . The led stays lit and constant until we put the engine car or a passenger car is put on the track . Then the led light blinks and the engine acts like it wants to go but doesn't . It's headlight blinks and it goes forward a touch then nothing .
  • Steve Braun
    I don't think this is a CW80 ?
    This is the DC version of the Polar Express with the remote. Please refer to the service manual at http://www.lionel.com/media/servicedocum...
    This version does have two neoprene belts on two of the drivers. Make sure they are both seated in the wheel groove. It still does not make sense to see the light blink when only the passenger car is on the track. The DC power pack may be acting on an overload condition in error, in which case it is not the engine or car issue.
    Do you have access to another DC source i.e 6 V battery you can connect to the track to run a quick test? Just make sure you get the polarity correct. If the engine moves, it is then obvious it is the DC power pack.
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
2answers
I just built a model railway but my train will not run?
If your train is not running you should check the 6 following things:
1. Is the train sitting on the Track?
2. Check All Electrical Connections.
3. Clean Track and Wheels.
4. Check the Power Supply.
5. Check the train is working (try putting another train on the track)
6. Check the Track and Wires.
You should be able to locate the problem by doing the above checklist.
1helpful
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
The gate stays down when the power to the train is on
The breaks should be on one of the outside tracks along with a wire to the gate and the ground wire from the transformer is attached to the other outside track. Power wire is attached to the center track and the power terminal on the crossing gate. When the train passes the break the metal wheels connect the ground rail to the rail with the break that is wired to the gate. This completes the circuit and the gate goes down. Once the train passes the other break the connection is lost and the gate goes up.
I need the codes for mi jumbo universal remote on my tv sharp
  • 004
  • 009
  • 079
  • 095
  • 111
  • 112
  • 123
  • 124
  • 173
  • Those are all the codes from the manual for Sharp T.V.s
  1. So now turn the item on you want to control with the remote.
  2. Press the corresponding button.
  3. Hold "set" till the LED stays steady.
  4. Enter the 4 digit code.
  5. When entering the 4th number the LED should shut off.
  6. This means that your remote is set for that device.
  7. Press OK to store the code.
  • If the LED blinks 3 times and goes steady again the the code is not the one you want and you need to start an step 1 again.
  • You can also try the Code Search Function
  1. Turn on the device you wish to match with your remote.
  2. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red.
  3. Press the button on the remote for the item you want to program.
  4. The LED light should blink once and then remain a solid red.
  5. Press the On/Off button slowly until the device you want to program turns off.
  6. The LED light will blink once each time you depress the On/Off button.
  7. When the device you want to program turns off, press the ENTER button.
  8. The LED button will turn off and the code for that device will be stored in your remote.
Regards, Tony
4helpful
2answers
My syma s107g gives a flash light in the circuit board and does not work
fully charge your heli----turn on transmitter-wait 2 seconds-turn on heli
wait for blinking green led to stop blinking-turns steady.....rev up
with a quick full throttle and back to idle--happy flying
2answers
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
4helpful
2answers
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
1helpful
2answers
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
2answers
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Top Lionel Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
