Got an error code E000020-0340. Can anybody help with the code description. Probably one of the drums by the related answers in other posts.
Posted by Tom Treharne on
sahoo_sanjay
    Master:
  • Office Equip... Master
  • 553 Answers
Dear
It may unable to adjust the control voltage at Bk inductance initialization.
1. Check if the Drum Unit (Bk) is installed.
2. Check the Drum Unit Relay PCB (Bk)
3. Check the Drum Unit Memory PCB (Bk)
4. Check the harness/connector between the DC Controller PCB and the Drum Unit Relay PCB (Bk)
5. Replace the Drum Unit (Bk).
6. Replace the DC Controller PCB.
Thanks.
Posted on Feb 10, 2015
Error 027-0400 canon 5240i
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR%20Advance%20C5560i&code=027-0400-05
Canon iR Advance C5560i Error Codes
Quoting from link:
Code
027-0400-05
Description
Error in supply with K Developing Assembly
Causes
The Toner Supply Screw Rotation Sensor detected rotation error within the specified period of time.
Remedy
[Related parts] R1.01 - Harness between the Feed/Drum Driver PCB (UN2/J225) and the Developing Motor (Bk) (M8/ J6011) - Harness between the Feed/Drum Driver PCB (UN2/J212) and the Toner Sensor Relay PCB (Bk) (UN42/J1430) - Developing Motor (Bk) (M8) - Developing Assembly (Bk) - Main Drive Assembly - Set-on Hopper Assembly - Feed/Drum Driver PCB (UN2) [Remedy] Perform the following in the order while checking whether the error is cleared. 1. Check that the Developing Coupling of the Developing Assembly is not damaged. 2. Check that the Developing Coupling of the Main Drive Assembly is not damaged. 3. Check/replace the related harness/cable, connector and parts.
Apr 29, 2018 | Canon Office Equipment & Supplies
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
Error code E000716-0000 on canon iR3320
Those codes are usually related to a hardware failure in the machine, probably a specific color drum unit or possibly fixing section...prob going to need a service rep to help you on that one if a simple power cycle didn't clear the issue. If your tech savy I might be able to guide you through a code reset. Thanks
Feb 18, 2014 | Canon imageRUNNER C3200 Copier
Canon IR C3200--error code E000020-01b0 explain this code please
Hi there
Error code E000020-01B0
That code relates to the yellow drum unit.
The unit was probably damaged taking it in an out.
Needs to be replaced.
Or try.
1. Information UPDATE UPDATE - the Drum units are as follows:
Yellow - 746
magenta - 215
Cyan - 758
Black - 9
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 04, 2010 | Canon imageRUNNER C3200 Color Printer
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
F33 error code. drum begins to rotate and then
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
Error Code showing E000020-0160. Help soon.
Your error code relates to your yellow drum unit. It probably need replacing. Enter service mode by pressing - the additional functions key (key with star in it) then 2 and 8 together - then the additional functions key again. This will bring you into service mode. Now select 'COPIER' and then 'MISC' this will then list the drum life in percent for each colour drum unit - you'll probably find that it is well over 100%. Maybe even 200 or more. In any case this is just an indication because the drums can even last 300% at times. You'll probably need a new drum unit.
May 09, 2009 | Canon imageRUNNER C3200 Copier
Error code sc 387 on my Ricoh Aficio 4006
You'll need a tech to run a diagnostic mode to find the exact cause...could be development problem, Transfer belt, ID sensor, etc
Feb 22, 2009 | Ricoh Aficio 450 Copier
Error Code 9-357
Don't have the codes for that one BUT 09 --- codes always refer to drum/toner problems. Make sure the drum unit is plugged in properly, and cables/plugs etc secure
Jul 19, 2008 | Xerox DocuColor 12 Color Copier
105 people viewed this question
Marvin
Marvin
