Question about NEC Ip2at-12txd Phone/telephone Handset black
How do I turn off the on hold music? - NEC Ip2at-12txd Phone/telephone Handset black
Posted by Rod Chanes on
ray gallant
    Top Expert:
  • NEC Master
  • 69,204 Answers
Only way I ever heard of is to hang up
Posted on Feb 09, 2015
How can i turn on music on hold Panasonic kx-t7731. i dont have anything on now
Music on hold is connected to the phone system controller. The audio from the source (usually a MOH radio) is connected to the MOH port on the controller.
Nov 03, 2015 | Panasonic KX-T7731 Corded Phone
How to stop the hold music from playing through the speaker constantly?
press [Feature] # 86
to turn off Background Music (as Nortel calls it).
F86 to turn on
F#86 to turn off
Sep 29, 2014 | NorStar M7324 Telephone
How do I turn on the hold music? When a call is on hold, the caller hears nothing and might think they have been cut off. I have pressed "1" on the handset but nothing happens? This is an Advanced Hybrid...
Gess where the music comes from? On the side of the cabinet, or next to the place where all the jacks plug in (depending on system) there's a port called EXT MUSIC or MOH. That's where the music or promotion on hold gets plugged in and then you need to do some system programming to turn it on.
If you Google MUSIC ON HOLD PLAYERS, you'll find a source of good hardware that will let you program or have promotions produced.
Carl
Oct 19, 2010 | Panasonic KX-T7730 Corded Phone
Phone is playing music as if on hold constantly. How do you turn this off?
Sounds like your music on hold is also your background music. Need to use the background music on/off code to toggle this feature to the off setting. Don't have it in front of me, should be Function,49, Function.
Jun 15, 2010 | NEC Electra Professional ETW-16DC-2
Meridian 7310 phone - any way to turn up volume on hold music???
Music on hold comes from an external box attached to the system cabinet. It should have a volume control on that box.
Feb 04, 2009 | NorStar Meridian M7310 Phone
I can't get the on-hold music to work for our 7731
There could be a number of reasons and it depends on your phone system.
In a TA series, you need to turn on Music (program 111). Additionally, in an 824 you need to enable it per phone (pgm 626).
In the TAW/TDA/TDE family, it has to be turned on (710/711/712), and the code for music is *7511 (0 turns it off).
In the TD series, you use program 803 to select a source or none.
Those are the most recent Panasonic systems. If it still doesn't work, post back with the exact model number of your system cabinet and I'll check if there's different instructions.
Carl
Nov 17, 2008 | Panasonic KX-T7731 Corded Phone
Need to change hold music ASAP
How about turning off the Music On Hold source at the phone system. It will be an external device ( radio, mp3 or cd player ) and turn it back on when you are on-line.
Jul 24, 2008 | Toshiba DKT 3010 Corded Phone
Music playing
If your phone does not have a dedicated Music button it is usually the HOLD button. Try the hold button first (with the phone hung up) if that does not work look for a button labeled music or possibly a soft key (key's labeled by an LCD display)
Aug 27, 2007 | Panasonic KX-T7730 Corded Phone
Can't switch the music on
Press SP-PHONE * 7511 SP-PHONE to turn the holding music on Press SP-PHONE * 7510 SP-PHONE to turn the holding music off
Aug 17, 2007 | Panasonic KX-T7630 Corded Phone
NEC Ip2at-12txd Phone/telephone Handset black Logo
122 people viewed this question
Top NEC Cell Phones Experts
Marvin
Marvin
Zaid Anarwala
Zaid Anarwala
Muntejaya Ginting
Muntejaya Ginting
Are you a NEC Cell Phone Expert? Answer questions, earn points and help others
