HP Officejet 6700 Premium E-All-In-One Logo
M
Maz Manns Posted on Feb 09, 2015
I have a HP 6700, have just put a brand new HP magenta cartridge in and it now will not print magenta at all...please help? i have cleaned print heads 3 times
ehsan vossough
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Feb 09, 2015
ehsan vossough
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
1096
Points
22
Please clean the contacts on the back of the cartridge with soft tissue and some ethanol. Also check if contacts are not damaged.
5 Related Answers
steve shroder
  • 141 Answers
  • Posted on Sep 14, 2008
SOURCE: hp 4650n
go ahead and replace the toner cartridge because it is probably dumping magenta toner in your machine. the cause of this is most likely a bad drum cleaning blade in the toner. if you do have toner in your machine you can spray windex on a lint free cloth and wipe out the spill. or use a can of air to blow it out but be warned you may have a magenta cloud in the room for several minutes. good luck!
Anonymous
  • 8637 Answers
  • Posted on Jan 25, 2009
SOURCE: I have hp8250 photosmart printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Anonymous
  • 4 Answers
  • Posted on Apr 03, 2009
SOURCE: will not print in red
hi, i have seen the same problem before in other models but not this one, but i think the solution i have will help you.
try cleaning the scanner unit using a dry cloth, clean all the small glasses carefully avoiding scratches. dont use a blower.
pineworks
Clive
  • 4362 Answers
  • Posted on Feb 21, 2010
SOURCE: My HP C6180 is not printing its magenta color.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Testimonial: "Thanks for you good advice. It all made sense to me and it should have worked. I found 9 others reporting the exact same problem. Craig patentQ.com"
PrintDocta
  • 217 Answers
  • Posted on May 09, 2010
SOURCE: HP 2605dn printing pale on magenta
This is likley to be the common problem (with this model of printer) of the laser unit having dirty lenes and/or mirrors.
Typically the magenta is the first colour to deteriorate.
To rectify this problem there's a fair bit of dismantling to be done in order to get the laser unit out.
Then you can open the laser unit up and clean the lenses and mirrors CAREFULLY. You don't want to scratch the surface silvered mirrors, or disturb the alignment of any of the optical components.
You'll see the same problem and solution for HP1600, HP2600, and Canon LBP5000, as they all use the same laser unit.
Magenta light flashing
Check your lights , this printer has a user replaceable print head as well as the ink cartridge http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c00844061
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
1helpful
My magenta and light magenta are not printing. The levels are nearly new. but the test diagnostic page is blank for magenta and light magenta. I tried brand new inkjets and the problem contnues. I have...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
I have an HP Photosmart 8250. I changed the Magenta cartridge and it seemed to work fine for a while and now when I print, the Magenta fails to come out. I have a Purge test that is basically an entire...
please if you are not professional technician then don't do this.but you can use some cartridge head cleaning solution.on the print head.if problem not solve then replace the cartridge.
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
My printer is not printing magenta. I have changed the cartridge (hp one), cleaned the print heads and
The magenta print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked magenta print nozzles. Also check the magenta cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Ink clog between magenta cartridge and print head.
print head may be burned out try cleaning it then tap the cartridge and try a test page to see if it prints, if it still does not work try a new cartridge if that does not work then the print head is burned out, it may be under warranty you can go to www.hp.com and input your model and follow the trouble shooting guide and if you can't fix it you can register for free live chat help with the problem and it may be under warranty, many printers are having problems with this color cartridge drying up and causing problems not only hp but other brands as well. I suspect the pigment drys up but am not sure about it.
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
D7260 not printing some colors
1.Try placing sheet of Magenta print on copy board, and run many copies .  Run head clean after about each 50 sheets.
2answers
Printing colours
The color cartridge is faulty, you need to replace it.
If it is new ask a refund.
After putting a good cartridge do head cleaning.
k24674
Grand Canyon Tech
Grand Canyon Tech
