Hi Prasanthi.
On front load machines, some manufacturers us de as 'door error'. This generally relates to a fault with the interlock mechanism.
This is the door lock which prevents the door from being opened while the machine is working..
If the door won't lock and/or the machine won't run. OR the door is locked shut, then this is the most likely situation.
The interlock switch is part of the electrical circuit.
NOT recommended for a handyman.
It's not a big job for a technician, and you will probably need a new interlock.
Good luck.
Nomess
Interlock switches look like this.....
