Question about Samsung HLN567W 56" Rear Projection HDTV
The picture went green. I was able to replace the DMD board with a used one and the picture returned just fine. Shortly after, the sound began giving problems. At first is would have no sound when you first turned the set on, the after a litte time, the sound would begin to work spotty at first then it would be ok until you turned the set off. Now the only sound the tv speakers make is a clicking sound. It makes this sound anytime the set is on. We listen to the tv through a separate stereo receiver and speaker. Any suggestions are appreciated. Thank you,
First, try to connect ext speakers. If the sound is OK just replace speakers. Otherwise the problem in amped sound output.
Posted on Feb 09, 2015
Thank you Vladimir. There are not external speaker jacks. I suppose I can go into the cabinet and splice in another speaker. Do you suppose that both speakers would have failed at the same time? I believe that the problem is somehow related to the video repair that I did. Is there some compatibility issues with different DMD Boards?
May 03, 2010 | Samsung HL-P4667W 46" Rear Projection HDTV
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Dec 07, 2009 | Samsung Televison & Video
Jul 25, 2009 | Televison & Video
May 05, 2009 | Samsung HLN5065W 50" Rear Projection...
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
Jul 12, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Dec 02, 2007 | LG 50PX4DR 50 in. Plasma TV
Oct 24, 2007 | Samsung HLP5085W 50" Rear Projection...
Nov 19, 2017 | Samsung HLN567W 56" Rear Projection HDTV
102 people viewed this question
