I purchased a Hudson Reed Jazz Dream Shower Panel model no TRUAS397. Temperature is either 100% hot or 100% cold. Did I install something incorrectly?
I have installed the shower panel but when I turn it on the water is either 100% hot or 100% cold. If I turn all the way to the left, hot water comes on. If I turn all the way back to the right, cold comes on. Anywhere in between water either stays all hit or all cold. Did I do something wrong in the installation?
I have exactly the same problem with a Hudson Reed UFG-HR716 3 way diverter. It's either 100% hot or 100% cold. Ive tried the temperature adjustment but that isn't working. What solution did you come up with?I have exactly the same problem with a Hudson Reed UFG-HR716 3 way diverter. It's either 100% hot or 100% cold. Ive tried the temperature adjustment but that isn't working. What solution did you come up with?
You can't post conmments that contain an email address.
You haven't provided much information to help narrow down the source of the problem.
Is the flow of both hot and cold water flowing freely? Are the water lines not clogged internally with corrosion or residue? Is it possible that the water is being diverted such as in an apartment building or to an outside spigot (sprinkler system) or kitchen faucets (dishwasher)?
Is your water heater temperature setting correct and is it supplying sufficient hot water flow to the shower?
Do you have a temperature balance cartridge in your shower faucet? If yes, it could possibly be faulty.
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
with out a water circulator every thing takes time ----------- sounds like the thermostats going bad you do have a 10 year warranty on this faucet type in your browser hudson reed kia faucet
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
try this.
if you have anti scald device installed in the valve, take it out. the anti-scald device is to keep the hot water from pouring out in case the cold water pipe is not functioning. In general sense, it is a good idea, however, it also mixes too much of cold water, therefore you don't get eough hot water.
