Question about Denon AVR-E400 7.1 Channel 4K and 3D Pass Through, Networking AV Receiver with AirPlay and Multi-Zone
How to connect a denon avr-e400 receiver to a televion
Connecting cable to back hdmi of the reciever and a hdmi input on tv
Posted by mark strack on
Anonymous232
    Genius:
  • 1,552 Answers
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Posted on Feb 09, 2015
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
Denon avr-1908 no picture from dvd player which is a panasonic...using hdmi cable
if your not getting a picture make sure you have change you signal setting on the reciever if you have done that. and you know your connections are right and you you are going from your dvd into the reciever and then the reciever to the tv with hdmi check you tv as well make sure you have switched your input signal to to the video source were your plugged into the tv i dont know what kind of tv you have but you may need to double check that
Nov 11, 2009 | Denon AVR-1908
Connected denon avr 1800 reciever to new hd tv. i cant find my reciever manual. how do i set the reciever to play the tv sound?
If you connect your tv's audio output to the reciever's audio input in the (TVor video section) using audio cables only---red & black or red & white) then select TV or Video on the front of the reciever depending on which connection on the back that you use it should work fine!!
Nov 06, 2009 | Denon AVR-1800
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
Connecting PS3 to Denon AVR-3805
refer to manual
http://www.playstation.com/manual/pdf/PS3-01-1.0_2.pdf
think you can use AV multi out connector
Nov 10, 2008 | Denon AVR-3805 Receiver
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Denon AVR-E400 7.1 Channel 4K and 3D Pass Through, Networking AV Receiver with AirPlay and Multi-Zone Logo
269 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
