Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
How to fix a volume control on an Altec Lansing inMotion im600. +toggle doesn't work anymore, -toggle has reduced the sound to zero.
Let the battery drain, and then reboot the player.
Posted by Kevin Liske on
4 Related Answers
Anonymous
SOURCE: Remote Control Altec Lansing IM600 - Battery
Turn the remote upside down. At the bottom, there is a slot that opens the battery tray and a series of grooves that are part of a clip that releases the tray. Insert the fingernail of your thumb into the grooves and the fingernail of your index finger into the slot. Ease the grooves (clip) toward the middle of the remote and slide the tray out. There is a ridge in the tray that matches the battery only when the battery is in the proper position. Slide the tray back in. If the remote doesn't work, you've probably inserted the battery in the wrong position.
Posted on Feb 16, 2009
Anonymous
SOURCE: lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email [email protected] and I will invoice you through paypal. Thanks
Posted on Mar 29, 2009
Anonymous
SOURCE: Where to find a speaker replacement for InMotion IM600
hi,i have 2 speakers salvage from im600 [email protected]
Posted on Apr 27, 2010
Anonymous
  • 6 Answers
SOURCE: how do I open the altec lansing inMotion im600? I
There is a button on the front of the unit that is just below the LCD readout that shows FM / iPod status. Press the button. If it does not open the unit, you may need to tap the back of the unit when doing this or else get something to gently pry open the unfolding section WHILE THE BUTTON IS PRESSED (otherwise you'll break the mechanism and won't be able to lock it again. It sounds like whatever you put in to create the connection may be jamming up your opening.
The unit comes with several adapters for different iPod models, you may want to try a different adapter; you shouldn't need to put anything else in it to maintain a connection. If you don't have those adapters anymore, you can probably get them off the altec lansing web site.
Posted on Jan 23, 2011
My IPod reboots continuously, what's wrong and how do I fix it? It gets to the Apple logo, then reboots. I tried iPod built-in diagnostics, disk mode works, and draining the battery has no effect after...
It sounds like it is the Hard Drive itself. It could have taken a tumble and been damaged. Try syncing the IPod to the computer and resetting it back to factory settings. If it does not work I would recommend either getting the hard drive replaced or buying a new one. Whatever is more cost effective. I hope this helps.
My brother's MP3 player is messed up. When you boot it, it automatically goes to recovery mode. Here, it tells you the firmware and gives me a couple options: Recovery Mode Creative Zen Micro...
Couple things to try.
Let the battery drain completely, then do a full charge and try again.
When turning it on, don't hold the ON slide, just slide it to ON then let it go. Holding it will send it into recovery and reset mode.
5helpful
How do I open the altec lansing inMotion im600? I
3helpful
How do i reset my mp3 player its just frozen?
How Do I Fix My Sony MP3 Player That Froze & Won't Turn On?
Sony Walkman MP3 players, like most MP3 players, can occasionally freeze up and stop working properly. Fortunately, there are two simple ways of resetting the Walkman system. The first method takes only 10 to 15 seconds to complete and is an effective way to troubleshoot most technical problems you may have with your Walkman. The second method, unfortunately, may take several hours; it requires you to allow the battery to drain completely. Whatever the problem is that's causing your MP3 player to freeze, one or both of these methods should clear it up.
Instructions
Things You'll Need:
* Paperclip
* Walkman MP3 player charger
Reset Button
Straighten the paperclip and set it aside for now.
Locate the reset button on your Sony MP3 player. On most models, it can be found near the volume control mechanism.
Insert the end of the paperclip into the reset button and hold it down for three to five seconds. When the screen flickers, you'll know that the MP3 player's system has been reset.
Remove the paperclip and wait for the system to reboot.
Battery Drain
Turn on your MP3 player.
Let the battery's life deplete. Since the system is frozen and no music is being played, this will take longer than usual.
Check that the battery is completely depleted. Sometimes the screen just goes dark during this process, but the battery is not actually drained. You can check this by pushing buttons or trying to power up the system.
Connect your MP3 player to its charger and plug it in to a power source. Allow the MP3 player to fully recharge.
Power on the MP3 player. The system should be operating normally again.
IPod touch screen is frozen and cannot power off or do anything
You'll have to wait for the battery to drain before being able to reboot it.
Hi, I just got the new altec lansing ipod sound dock and a new ipod touch 3rd generation. The dock is not playing sound off of the speakers. Can you help me fix it?
have you turned the volume up from the speakers and the ipod?
thats usualy a problem people get
they think they have to turn volume up from ipod not dock
2answers
In Motion im600 unit seems to work for a few hours then just shuts down. If I wait a day or two it will start working again, then only for maybe a few hours. I've taken the battery out for a while then put...
5V AC adapter for Altec Lansing inMotion iM600 speakers http://lcdpayless.com/productpage.php?productId=172
13V AC adapter for Altec Lansing inMotion iM600 speaker http://lcdpayless.com/productpage.php?productId=170
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
