Numbers on this Device: C_NO:E16356.J00543 FCC ID: S4LONE-ED 4N00.004 IC:5767A-ONE-ED N14644 I took the sd out and put it in a rental van built in Tom Tom One satnave, it didnt work in the rental van and when placed back in my own unit and it never worked, showing the sd card coming out of the unit then a red cross goes through it and repeats same thing, I have tried hooking it up to tom tom website and downloading info again, when disconnected, it goes back to displaying the same thing.
SOURCE: When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
SOURCE: When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
SOURCE: red cross on sd card on startup
You can not use a sd card from one TomTom and put it into another TomTom. The operating system on the card is coded for each individual TomTom device. First try doing a reset with the card installed on your dads TomTom. The reset hole is on the bottom of the TomTom marked reset Use a streightened paper clip, insert the paper clip into the hole until you feel a click then hold it in for 20 seconds. If that didn't work and you have a card reader insert your dads sd card into the reader and make a backup of the everything on the sd card. Just copy and paste everything on the card to a folder on the desktop you have created on your desktop. Next delete everything on the sd card EXCEPT the maps and ttgo.bif or ttgo.bak file. Now that you have made a backup and deleted everything on the sd card except for the maps and ttgo.bif or ttgo.bak open TomTom Home. TomTom Home should see your card and install the operating system back onto the sd card. If it doesn't you may have to insert the sd card back into your dads TomTom and connect it to the pc. It may take a few times of doing this to get the latest operating system back onto your dads TomTom. You can do the same for your TomTom, but you cannot use any thing bigger than a 2 gb sd card. Do not get sdhc cards they won't work. This will only put the operating system for your TomTom onto the sd card. When you have installed the operating system onto your device it will say "no maps found", you will have to buy the map from TomTom..
SOURCE: My device seems to have frozen with a red cross in the bottom rig
The above is not a question!
So, please state your problem.
Bye for now.
SOURCE: hi, I have tom tom
Please follow the steps below to solve the issue. This is caused by an update. If you are not sure, how to do this, call TomTom help line for assistance. STEP 1 - Find the mapsettings.cfg Good Luck!
- Connect your device to the computer and switch it on
- On your PC, click on My Computer to access your TomTom drive. On a Mac you can double click on it on your desktop
- Inside the TomTom drive, you will see a list of folders (on Windows these are yellow, on a Mac they are blue) as well as some loose files
- Please find the folder that is named as the map on your device i.e. United_Kingdom_and_Republic_of_Ireland_or_Western_Europe etc
- Double click on this folder to access it and please find the file called mapsettings.cfg
- Please delete this file
STEP 2 - Creating a manual backup of your map
- Right click on this folder and copy it
- Go to the desktop of your computer and paste the map folder
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your map.
STEP 3 - Format your TomTom device
IMPORTANT: ONLY continue if you were successful in making the back up of your device
For PC users:
- Open My Computer. Right click on the TomTom device drive and click 'Format'. Make sure Quick Format is not selected.
For Mac users:
- From the Finder menu, click 'Go' > 'Utilities', then double click 'Disk Utility'. In the 'Disk Utility', select the volume below the TomTom disk. Make sure the 'Format' is set to 'MS-DOS (FAT)' and click 'Erase'.
STEP 4 - Remove old files from your computer
- Open TomTom HOME
- Click on 'Manage my device'
- Click on the 'Items on computer' tab
- Tick the options for 'Applications' and 'Voices'
- Click on 'Remove items from computer'
STEP 5 - Install the software on your device
- Click on 'Update my device'
- Tick the options for 'Application' and at least one voice (eg, Jane)
- Please do NOT select your map at this stage.
- Click on 'Update and Install'
- Click 'Done'
Your navigation device starts and then connects to the computer again. HOME may offer more than one application update. Please repeat this step until no further application updates are offered.
STEP 6 - Restore the map
- Find the map you copied to your desktop and copy it again
- On your computer go to 'Start' -> 'My Computer' and open the TomTom drive
- Right click anywhere and select 'Paste'
STEP 7 - Check the Device
- Eject the drive (on Windows, go back to My Computer and right click on it and select Eject; on a Mac, drag the drive into the trash)
- Please disconnect your device and let it load up as normal
- You should now be able to set up the device as normal
