Question about Pioneer Car Audio & Video
Installed pioneer dxt-x2769ui/4speaker bundle a month ago.. worked fine til yesterday. Radio on everything fine. Then instantly no sound at all. Radio was still on like nothing happened. Lights... cd
Installed pioneer dxt-x2769ui/4speaker bundle a month ago.. worked fine til yesterday. Radio on everything fine. Then instantly no sound at all. Radio was still on like nothing happened. Lights... cd playing.... digi eq pulsing... just no sound. Turned radio off and back on... heard a click in the speakers but nothing else.... any ideas?
Posted by blake m nelson jr on
jnjholding
    New Friend:
  • 147 Answers
You likely have a bad speaker or shorted wiring. Aftermarket radios shut off the outputs when a short is detected.
Posted on Feb 21, 2015
5 Related Answers
KaeZoo
Brian Neathery
  • 156 Answers
SOURCE: power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Posted on Aug 11, 2007
Anonymous
SOURCE: Pioneer DEH-9600: No power to rear screen
bad ribbon cable
Posted on Mar 25, 2008
Anonymous
  • 125 Answers
SOURCE: OWNER MANUAL
everything is controlled for the radio by the little remote. the top right has a source button. press that button a couple of times and watch the screen as you do.
Posted on Sep 24, 2008
sforza
SOURCE: Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Posted on Dec 02, 2008
Anonymous
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
Main control button not responsive to set function levels.... Is there a way to reset the unit?
Check and see if there is a reset button behind face plate on unit itself......
May 29, 2016 | Pioneer Audio Players & Recorders
How do I install my system into a 2006 sonata
Make sure that you have the correct wires and connections before you start. I would suggest that you use the services of a shop that specialises in fitting units as it is very easy to get it wrong and other circuits in the car become affected.
Jan 27, 2015 | 2006 Hyundai Sonata
Does a pioneer DXT-X2769UI car stereo have an illumination wire?
White/green also check and see if your switched 12v and constant 12v are correct I have had one that wires were flipped in the manufacturing process... good luck
Dec 24, 2014 | Mercury Cars & Trucks
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
PIONEER STEREO DXT-2266UB
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual = http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-2266UB_OwnersManual0607.pdf
1997 PONTIAC FIREBIRD WIRE COLORS
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
May 20, 2011 | Pioneer Car Audio & Video
Sound Just Stopped Working
I have the same problem with my 49txi, and I called pioneer and a repair shop as well. Both told me that the 49txi has a known problem with over heating and that its boards unsolder themselves. I would have thought Pioneer would stand behind something this expensive, but that was the old Pioneer in the 80s, and the new Pioneer says we are on our own.
May 29, 2008 | Pioneer VSX-49TXi Receiver
Car Audio & Video Logo
412 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
