Question about Metra Ford F 150 Truck 1999
How do I disengage F 150 4x4 from 4Low
Tried backing up with truck in N
Posted by Mattie Kirk on
paul srigley
    Sergeant:
  • 337 Answers
Try backup a bit put in neutral wait then drive
Posted on Feb 08, 2015
My2000 ford excursion wont completely disengage out of 4 wheel drive
Sometimes you have to back up about a foot to disengage the hubs.
Feb 07, 2017 | 2000 Ford Excursion
Can not disengage 4 hi to 2hi
Try rolling back and forth with the front wheels straight, whilst trying to disengage back to 2 hi..
Feb 06, 2016 | 2005 Chevrolet Chevrolet TrailBlazer EXT...
2003 blazer service 4 whd comes on I can't get it out of 4 whd
drive the blazer in reverse for 200 or 300 hundred meters, then try to disengage, this will work, also, take the blazer off the road, onto loose stones, sometimes the axles bind, this will allow the wheels to free spin, . then put in reverse, drive it back & forth a few times, on a dirt or gravel road, . and it will disengage .
good luck, .let me know how you get on.
kipp
Jan 21, 2015 | 2003 Chevrolet Trailblazer Ext
Traverse awd won't disengage
Try backing up STAIGHT for 50 feet making sure the switch is in the 2WD position. If this does not work, then you need to check that power is getting to the Actuator
Feb 13, 2014 | Chevrolet Traverse Cars & Trucks
1997 chevy Pickup wont come out of 4WD
solenoid is sticking have had this probem before
Jan 30, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
4 wd is engaged in 4wlo, but when i try to disengage it wont.
Try backing up straight about 50 feet and try it again. Sometimes drive line strain can build up, especialy if you've been driving on hard, dry ground or turning a lot. By backing straight up you relieve that strain and there is less pressure on the gears so they will disengage.
Jan 09, 2010 | 2002 Jeep Liberty
4 wheel drive will not disengage
Once you turn off four wheel drive back truck up at least 20 feet. This should disengage.
Mar 22, 2009 | 1999 Ford Ranger SuperCab
Disengaging 4 W drive, 99 toyota 4 runner
either the tranfer case is jammed up or the electric motor than operates it is defective.
Feb 26, 2009 | 1999 Toyota 4Runner
Metra Ford F 150 Truck 1999 Logo
59 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
