SOURCE: avic-d3 to steering wheel controls
you need an interface, which then plugs into the back of the avic-d3...
http://www.pac-audio.com/products/productsCatagory.asp?mmSearch=Steering%20Wheel%20Interface
you might get charged up the *** to install it, i recommend if you have any friends who know how to install to help u out... havent even got around to installing mine yet cuz installers were telling me it would be 'custom job' cuz they haven't installed it before, and then you get the hourly rate n they can basically rape u if they want to..
cheers!
SOURCE: steering wheel controls
In most cases this problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament (ribbon type connector), the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to follow factory Airbag disarming protocol can result in an unexpected Airbag deployment and possible serious personnel injury or death.
SOURCE: how do you remove the old car battery on a 2008
SOURCE: Steering Wheel Control
I installed a body lift and now none of my steering wheel controls dont work any ideas
SOURCE: 2007 chevy impala LT, horn and cruise control not
most likely the clockspring or ribbon assembly inside the steering wheel has a broken spot in it. if you try to do it yourself be careful with the airbag system
