Question about Apple iPhone Smartphone
Iphone doesnt detect in Itunes and Usb wall charger doesnt work.
I have an Unlocked Iphone, but for some reason I can't connect to Itunes. It just doesn't detect when i put phone on dock? I tried on many diffrent computer but still. The usb cord, dock is in working condition. Also for some reason the usb charger that came with the phone doesnt work. I tried that charger on a Ipod and it working. I had to get a wall charger that is directly connected from outlet to phone and it works. Anyone who knows how to solve the problems please let me know
Thanks
Posted by nir44 on
  • 13 more comments
  • nir44 Nov 13, 2007
    Ya I have Itunes verison 7.4 . I tried all the version it just doesn't recognize nor it charger from usb. The usb is in working condition i got it tested thru apple and it works there.
    Any clue??
    Thanks
  • makura Nov 16, 2007
    I have the same problem. Doesnt charge through usb and pc does not detect the phone at all. Can anyone help?
  • nir44 Nov 16, 2007
    Makaura
    Is your phone unlocked? Do you know if your charger that came in the box works. For me if i use that charger it doesnt charge and it doesnt even charge if i put the usb in computer and connect to iphone. I thought the cable might be bad, but i got it tested thru Apple and cord works. Yet no communication between Itunes or any charger.
    Let me know what have you been trying lately it might help me solve my problem as well
    Thanks
  • Anonymous Dec 02, 2007
    Same problem also to me.
    USB cradle is working for recharging with wall power line but any MAC or PC are recognizing the usb connection.
    Any hints? Some wrong file configurations during jailbreaking?
  • nir44 Dec 12, 2007
    My problems is solved. I got the phone exchanged from Apple for new Iphone.
  • Anonymous Jan 10, 2008
    I have an ipod nano (first generation) and when I plug it into the USB in my computer, itunes will not recognize my ipod.
    I am able to charge my ipod when its plugged into the wall charger but not with the USB cord for the computer.
  • jens-wilsby Feb 06, 2008
    i have exactly the same problem, i downloaded one file from installer.app and then it went dead. It keeps restart and stops at the apple logo... Please help!
  • sysminus Feb 11, 2008
    I have the same problem... i ran ibrickr on a OTB 1.1.3 BL 4.6 then my iphone went green.. shut it off and when i turned it on.. Itunes or ibrickr wont find it anymore. cant connect to them... the phone would just show the apple logo then run the lines of code endlessly then reboots again and run t he lines of codes and reboots again.. over and over.. please help... anybody who has resolved this issue.
    sysminus
  • Anonymous Mar 15, 2008
  • CynthiaMa123 May 14, 2008
    my iphone is not charging anymore when cnnected with usb to my pc
  • love_for_all Jul 10, 2008
    everytime i connecct the iphone to my computer
    it doesnt recognize my iphone or it doesnt connect with itunes
    i have tried the thing hold the power and home button and connect usb again but i dint work
  • Anonymous Dec 04, 2008
    I plug my iPhone into my computer and nothing happens it just charges, but never appears in my iTunes. I've tried everything, uninstalling, and reinstalling the most up-to-date iTunes, resetting my iPhone, turning off my iPhone and turning it back on, deleting the backup files for my iPhone from my computer...IDEAS!?!?!?!?!
  • soalineorn Dec 22, 2008
    my iphone does not detacet with itune but i can charg battery from usb conection?
  • jibi Mar 23, 2009
    when i connect my usb charger in iphone i cannot acces the charger it is not showing the charging logo and when i connected to my pc it is not working
  • mauro1319 May 11, 2010
    every time i plug in my iphone my computer makes three beeps, the same tone as it usually would make when i unplugged it. it doesn't recognize my iphone when i plug it in but only makes that sound. It is jailbroken and i don't want to have to put in recovery mode because than i can't get it out and apple won't fix it for me since it has 3rd party apps. can anyone please help?
Anonymous
    New Friend:
BEST SOLUTION IS THROW YOUR IPHONE AND CONNECT IT TO THE PC AND BANG!!! IT APPEAR I DONE IT!!! TRY IT NOW !!!
Posted on Jan 13, 2010
Anonymous
Sysminus
i had the same problem. i did these steps and now it is recognized:
1. Closed iTunes
2. Disconnected iPhone from USB.
3. Open iTunes.
4. Hold down HOME + POWER buttons.
5. Reconnect USB to iPhone while holding down HOME & POWER buttons.
good luck
Posted on Mar 03, 2008
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Anonymous
Sysminus I also had the same problem I tried to download the guitar hero mod for TTR and that would happen. You need to restore it
Posted on Apr 17, 2008
Anonymous
    New Friend:
Problem Solved!
I had this problem, everything else except the iPhone worked fine. After some checking, it was noticed that the 5 Volt line feeding the USB port was nearer to 6 Volts. The problem was with the main PC power supply. The solution was to change to power supply and all was well. It seem the iPhone must check for an over voltage from the USB and if too high then will just not turn on. Modern mother boards do not consume much power on the 5 Volt line and therefore cheaper power supply units (PSU) tend to over-volt a little but should not reach nearly 6 Volts.
This can easily be checked with a volt-meter, back off PC, and find a spare 'chunky' 4 way connector, normally feeding the hard-drives. Measure the voltage across one of the black wires and the red wire which should be between say 4.5 and 5.5 Volts.
Posted on Sep 21, 2010
Anonymous
  • 4 Answers
U need to use itunes verison 7.4 and up (even 7.3 will do ).
cheers
Nikesh
Posted on Nov 12, 2007
How to unlock apple iphone 4 and use any other carriers sim card. thank you very much!
Unlock your apple iphone 4 and use any other carriers sim card
To unlock your apple iphone to use any sim card, you need to get the unlocked confirmation from apple by using any unlock code service provider.After getting the unlock confirmation you need to use i-tune to unlock it
here is the direct link of service provider to get the unlocked confirmation
How to unlock iPhone Factory Unlock iPhone
After getting the unlock confirmation you need to use i-tune to unlock it as below:-
How to Unlock the Apple iPhone 6 after getting the confirmation as Unlocked -
-Install the last version of iTunes on your computer.
-Make sure your iPhone 6 is updated with the lastest version of iOS.
-Switch ON your iPhone 6 with a SIM Card from a non-compatible network.
-Connect your iPhone 6 to your computer using the Original USB Cable.
-Launch iTunes andwait until iTunes detect your iPhone 6.
-Now disconnect your iPhone 6sand reconnect it after 10 seconds.
-Your iPhone 6 is now Unlocked!
Note:-In the unlikely event that your iPhone 6s is not unlocked, please restore your device following the official guideline from Apple - https://support.apple.com/en-us/HT201252
Sep 30, 2016 | Apple iPhone4 4G iPhone 4
Iphone 3gs unlock
One of the best method to unlock an iPhone 3GS is to unlock using remote unlocking service. You can get the remote unlocking service for an iPhone 3GS from www.wickedunlock.com/apple-iphone-3gs/rs16wp9/ at affordable cost. This method of unlocking is very simple. Here are the steps for unlocking an iPhone 3GS,
1. Wait for us to send you an email saying your phone has been activated or remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone 3GS phone software is updated to the latest version using the iTunes software.
4. Connect your Apple iPhone 3GS to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone 3GS.
6. Disconnect your Apple iPhone 3GS and reconnect it after 10 seconds.
7. Your Apple iPhone 3GS is now unlocked.
This method of unlocking doesn't require a jailbreak too. Anyway if you need to jailbreak your iPhone 3GS, You can get the guide from www.absinthejailbreak.com All the best mate.
Dec 03, 2012 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
No puedo desbloquear mi iphone 4
you can unlock your iphone..there are many software available to unlock iphone and my friend unlocked it by remote unlocking..there are many online providers who provide the service..one of my friend got unlocked his iphone from Wickedunlock by remote unlock..and here is the instructions
1. Wait for an email saying your phone has been activated or remotely unlocked.
3. Make sure your Apple iPhone phone software is updated to the latest version
4. Connect your Apple iPhone to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone.
6. Disconnect your Apple iPhone and reconnect it after 10 seconds.
7. Your Apple iPhone is now unlocked.
and the important thing remote unlocking is available for some country and network providers only so if you are interested you can try from them before that see whether remote unlocking is available for your country and provider..
Nov 26, 2011 | Apple iPhone 4 3G 3Gs Charger or Sync Data...
I have an unlocked iphone 4 but my computer doesn't detect my iphone 4 anymore.
Hi panggalory,
Is your iPhone 4 factory unlocked or jailbroken then unlocked?
Either way, please read the following:
  • Make sure that the USB cable is in good condition
  • Try connecting in different USB ports of your system
  • Reinstall iTunes to the latest version http://apple.com/itunes
  • Try connecting your phone in some other computer
The above solutions should work because I myself have faced this problem and these have worked for me. If it still doesn't work, the please let me know.
-Pragith
Jan 02, 2011 | Apple iPhone Smartphone
Restore problem with emergency call display all time
Your iPhone is not factory unlocked. This means if you purchased it from the USA you need a deactivated ATT SIM card to get it past the activation or use a program called QuickPWN to Jailbreak + Activate your iPhone
Feb 11, 2009 | Apple iPhone Smartphone
have you tried to reinstall itunes on your pc? it will be the iphone driver that is missing from your pc if you make a bacup of your itunes files in the itunes folder and then re install the most recent itunes from apple this will re install the driver needed to find the phone through itunes.
Jan 27, 2009 | Apple iPhone 3G
Tmobile sim still doesnt work after being unlocked.
if you have a 3g you cannot upgrade to 3.0 firmware and unlock it.
2g solution
3g solution
Jan 02, 2009 | Apple iPhone Smartphone
Based on your message it looks like Itunes reupdated the firmware of your Iphone back to the original factory firmware hence it is back to the Locked firmware. When you hit restore in Itunes it will check the Apple website for the correct firmware and load it. You will have to have the phone unlocked again. I would suggest you go to a cellphone repair center and have them unlock the phone again.
Aug 18, 2008 | Apple iPhone Smartphone
Iphone not detect
try updating iTunes
open iTunes > Help > Check for updates
install any updates, restart the computer and try again.
Post again if this doesnt work
(BTW if you dont already have iTunes, you need it for the iPhone to work http://www.apple.com/itunes/download/)
Jan 03, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
18,439 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
