Question about Nortel Business Series Terminal T7208 - digital phone
My nortel voicemail is locked
My mailbox for voicemail is locked and it says to contact admin. how do you fix this?
it was working fine and then just stoppped and locked me out saying that my passsword was no longer valid.
help!
Posted by mmpcca on
Anonymous
What password is no longer valid? The admin, the operator, the installer?
What are you pressing to log in?
Posted on Jul 07, 2009
Anonymous
You just need to have someone(system administrator) reset the password on your mailbox back to the default password. Good luck
Posted on Jul 16, 2009
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
Trying to change System greeting on my Avaya Partner 18D. How do I do it?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.
If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456.
Once your into the admin mailbox press 9 for admin programming. 3 for greetings, 1 for the auto attendant #.press 1 for the day menu or press 2 for night menu and 6 to modify the menu. press *# to skip selector codes.Press 1 to record your new greeting 1 to stop recording. Press *# to approve or 21 to re-record hang up when finished.
Oct 07, 2010 | Lands Phones
How to reset voicemail password on a Mitel superset 420?
contact your system admin or vendor to have the mailbox reset. The mailbox isn't inside the phone, it's a system that supports all the phones in your office/company.
Apr 21, 2010 | Mitel Superset 420 Corded Phone
How do I reprogram the main message on my Lucent Partner 18D and how do I access a line where my employee quit, so I can get her messages?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector codes, 1 to start recording 3 to accept greeting hang up when done.
As far as the employees voicemail messages, while in the voicemail administration you can reset her password in the "administer mailboxes" prompt which is either 2 or 4 depending on the voicemail type you have. that will reset her password back to 1234.
Apr 13, 2010 | Lucent PARTNER18 Corded Phone
An employee changed the password to the voicemail, and they are no longer with us. How do I override their password and change it back to the default password for the new employee?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,(depending on version) press either 2 or 4 administer extensions, enter the mailbox number of the box you want to reset, press 3 to re initalize the password, hang up when done
Apr 09, 2010 | Avaya Lucent Partner 616 Phone
How do I access the automated attendant menu on my Avaya 18 phone system?! thanks
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector code, 1 to start recording 3 to accept greeting hang up when done
Apr 06, 2010 | Lucent PARTNER18 Corded Phone
I need to program an outgoing message and don't have the manual for the lucent partner 18D.
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector codes2_bing.gif, 1 to start recording 3 to accept greeting hang up when done
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
USED AVAYA ACS V7 PARTNER MAIL vm SYS ANSWERING ALL CALLS, I CAN'T ACCESS VM SYSTEM
Depending on the type of voicemail you have, That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming2.gif.
Oct 06, 2009 | Comdial Avaya Partner ACS Phone
How do I change our voicemail?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming.
Oct 02, 2009 | Lucent PARTNER18 Corded Phone
Mailbox locked error message. when i try to check messages and enter my mailbox # and pw. it says mailbox locked, pls call admin. and then closes
You need to get into voicemail administration and reset the mailbox password. Open the mailbox (F981), enter the default password (0000) and the system will prompt you to enter a new password.
Good Luck!
Sep 08, 2009 | NorStar Compact Ics WithClid Trunk Mod...
Nortel Business Series Terminal T7208 - digital phone Logo
1,816 people viewed this question
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
Joel Rodriguez
Joel Rodriguez
MrFixitSTTL
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
