Question about John Deere Garden
John deere 970 tractor rpms steady go up when tractor is idling or in motion what would cause this..there is no increase in actual speed when this happens
Posted by Chris on
Dennis Key
  • John Deere Master
  • 2,481 Answers
Your throttle cable clamp by carb. may have come loose.
Posted on Feb 08, 2015
5 Related Answers
Anonymous
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
Freddyyesme
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
Anonymous
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
Anonymous
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
nova2nv
Bill Linda Rivard
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
What would cause diesel in oil on a 1070 john deer
If the injector pump is driven from inside the crank case the pump could be the cause of fuel in oil. I saw this problem happen on a Ford
Sep 30, 2013 | John Deere 670 770 870 970 1070 Compact...
1981 John Deere 1050 Diesel Tractor - Engine will go to high idle by itself. You can shut key off and engine will eventually die. What would cause the engine to high idle? Afraid engine will lock up.
There are 2 types of governors on diesels. one is controlled from the foot and is fixed speed at the foot setting. The other is variable speed which will run to high idle if the setting is not changed IE on start it will idle ok but if you use a fast setting on a hand throttle say to warm up the motor it will run to high idle. I suggest that if you have not had a problem before then you should have a diesel pump specialist look at it as there may be a fault in the governor control.
Jun 23, 2013 | John Deere Tractor Side Screen...
Does torque increase with increase in backpressure
No ..rateded at RPMs and torque curves related fuel delivery and eng displacement..
Apr 01, 2010 | John Deere Muffler 1010 Diesel Tractors
Only idle
Take that carburetor apart and soak in carburetor cleaner and run a small wire down each passage and blow out the passages with compressed air.
Aug 22, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
48 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
