No one started to reset
Are you sure it is asking for a serial number, or is it a password and or pin code. Machine will not ask for a serial number. Never in ten years have I seen that
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: I have a Konica Minolta bizhub C450. Can the image
It may, but this mean that next time you put toner on the machine, you will expect less copy quality and printing for each toner bottle.
SOURCE: how to reset konica minolta bizhub c450
you have to replace the parts its need or Replace Chip on the
image unit
Take the front plastic cover off the black IU and you will see the chip (a small pcb ) that you need to replace. Unplug the connector and remove the old board. Put the new pcb in and connect the connector.
SOURCE: Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
