Hi there here is the link to show u how to do this
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46515
hope this helps
1060 Keyboard
For access, remove this FRU:
v “1010 Battery pack for 14.1-in. LCD models” on page 73
v “1020 Battery pack for 15.0-in. LCD models” on page 75131a Note:
Screw 1a is only for the models with 14.1-in. LCD. Other models do not have this screw.
Press the part indicated by the arrow 2 in the direction of the arrow. This releases the latches of the keyboard from the frame, so that the front side of the keyboard pops out. 2 Pull the keyboard a little in the direction of the arrow 3, and then detach the connector 4. 34 Removing
and
replacing
a
FRU
82
T40/T40p,
T41/T41p,
T42/T42p
When installing: 1. Attach the connector 1.1 2. Make sure that the keyboard edges, marked a in the figure, are under the frame.aaa (continued) Removing
and
replacing
a
FRU
ThinkPad
T40/T40p,
T41/T41p,
T42/T42p
Series
83
3. To make sure that the front side of the keyboard is housed firmly, gently press the keys with your fingers and try to slide the keyboard towards you. 4. Make sure that all the projections on the front side of the keyboard b are firmly attached under the frame.bb 5. Secure the keyboard from the underside of the computer, using the new screws provided with the keyboard. Removing
and
replacing
a
FRU
84
T40/T40p,
T41/T41p,
T42/T42p
1070 DIMM (standard) For access, remove these FRUs in order: v “1010 Battery pack for 14.1-in. LCD models” on page 73 v “1020 Battery pack for 15.0-in. LCD models” on page 75 v “1060 Keyboard” on page 81112 When installing: Insert the notched end of the DIMM into the socket. Press the DIMM firmly, and pivot it until it snaps into the place. Make sure that it is firmly fixed in the slot and does not move easily. Removing
and
replacing
a
FRU
ThinkPad
T40/T40p,
T41/T41p,
T42/T42p
Series
85
