Cars & Trucks Logo
Ollie Oliver Posted on Feb 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have an fx45.Should the tach read 25-3000 ROMs when moving at 75mph? Auto tranny seems like it should be in higher gear.
Bill Boyd
Level 3:
Top Expert:
  • Cars & Trucks Master 53,816 Answers
  • Posted on Feb 07, 2015
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948069
Points
172802
There is not info to be able to give a definite answer
to work it out
you have top know the diff ratio, wheel tyre circumference to be able to work from rpms of the engine to road speed
However as a pointer, most cars will be around 3200 rpms at 60mph as this will be direct drive and od causes a drop in rpms
Being an automatic find yourself a good section of low traffic road and start from stop slowly increase the rpms and watch the rpms. keeping the accelerator steady you will see when the auto changes by a drop in rpms. slowly increase road sped until you see the next drop in rpms and so on. Over drive normally comes in around 55 mph or around 3000rpms
I would think that it is working because 3500rpms at 75mph is reasonable rpms to be expected. If it wasn't working I would expect the rpms to be around 3800 to 4000.at 75mph
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Aug 22, 2008
SOURCE: whinning sound tranny?
When does it whine? I would recommend a fluid change along with filter.
Dan
  • 17 Answers
  • Posted on Jan 03, 2009
SOURCE: tach on my 1995 eldorado is not correct
I have a complete dash for a 95 which should fix it. They are kind of a pain to replace, and the one I have has 91,000 on the odometer.
Dan Lemke
[email protected]
Anonymous
  • 716 Answers
  • Posted on Jan 06, 2009
SOURCE: Doesnt sound or feel like my cars shifting AUTO Transmission
Have You Checked Your Transmission Fluid?
Or Even Change It That Always Makes A Work Of Difference.
defadad
Harry Goodwin
  • 353 Answers
  • Posted on May 07, 2009
SOURCE: Auto transmission problem
your bands may need adjusting or the transmission needs to be serviced to find out if it is something more serious
Anonymous
  • 100 Answers
  • Posted on Aug 30, 2009
SOURCE: 2000 NISSAN SENTRA , SEEMS TO BE STUCK IN A GEAR
Sounds like a bad overdrive clutch, it's in the torque converter and is not repairable, you have to replace the torque converter, this is somewhat common on high mileage automatics, usualy it sticks locked, when you put it in gear it makes a clang and unlocks, but locks up as you drive and won't unlock when you slow down like it's supposed to
sounds like this one simply will not go into gear at all, either the clutch is worn out (They're vry small snd weak) or possibly a sticking valve body.
this needs to go to the dealership garage, NEVER go to Mr Transmission type places they'll want to overhaul it whatever's wrong, they don't waste time on diagnosis
2helpful
3answers
Why is my 2000 kia sportage 4x4 getting such a high tach reading2700 or higherwhen i drive 50 mph or faster with it in 5th gear?
Are you sure you are counting the gears right? Sound like Torque converter lockup is not working.
Just purchased my 2nd used Hyundai accent gs- 57,000 miles. I have been researching the cars problem of: 75 mph; in 5th gear, the rpm's are over 4000; making the engine noise almost unbearable! So what...
any "adjustments" you carry out to reduce engine speed at any given road speed will affect the speedo/odometer reading,BUT,the simplest/cheapest way of reducing revs is to fit bigger wheels/ tyres.say fit 15" instead of 13"with the same profile tyres.this will reduce your revs by about 500 @75mph.but the speedo will read 70mph.also acceleration times will be considerably reduced.and put an extra strain on the clutch/engine.
alternatively,swop the whole drivetrain to diesel,75mph=3500.
3helpful
97 Chevy truck cluster and transmission
I would say its your Ignition switch or the fuse for tranny is blown or the tranny is unplugged.My truck had a problem where it was stuck in third gear, the tach never moved,the gear indicator light went out.I left it at the tranny shop all day and nobody could find the problem.All you need to do is check your fuses with a test light.I looked at all my fuses and they were all good but when I used a test I found that some fuses didnt have power supplied to them from the ignition switch.Your fuses need power on both sides to complete that circiut.So I would say go get a test light because they are cheap and check your fuses before you go right back to the parts store for that ignition switch.Good Luck
4helpful
1997 960 volvo.think? auto tranny pump makes whinny noise cold.
Your transmission is going to fail sooner or later, the whining noise you hear is the the clutch packs in the transmission going out.
1helpful
02 escape 4x4 3.0L TRANS OVERDRIVE
I would recommend taking it to another tranny shop. Because if the tach is higher than normal then more than likely its slipping. Eather way what ever it is. I wouldnt wait till the last min, because it could be just the tranny pump and if so then it can be saved before it wrecks havoc on the tranny.
2helpful
3answers
Chevy venture 2004 Transmission
Bring to tranny shop or repair shop, have it scanned for trouble codes, many electrical parts and solonoids in those trannys, possible it may just be a shift solonoid bad or needs adjustment, much cheaper than replacing tranny. good luck!
Whinning sound tranny?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
