If the inline pump is not working no hot water will flow into your radiators. The pump pushes the water in the lines to create a water flow. Increasing the pressure will not help in this case. I recommend you put the pressure back down as it usually is preset when the boiler is installed. My pump is about three feet back of the boiler on the intake line. If you don't know what you are doing I recommend getting a repair man as you could create more problems by over heating the boiler its self and blowing the electrical parts up.
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
SOURCE: My worcester Combi boiler loses pressure over 24
check the tops of all your radiator valves for bypass if found, easy to repair best of luck
