Question about Home
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Moving around the hours allowing the chimes at each quarter. While doing this the hour chime is chiming continuously. .?
Posted by Douglas Field on
UsedClockPartsdotCom
  • 277 Answers
Not all mechanical clocks that play the westminster chime can be turned off (have a lever). Some do but most do not.
Tim
UsedClockParts.com
Posted on Dec 16, 2016
Buddy strong
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Posted on Feb 07, 2015
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Sep 21, 2015 | Seiko Mantel Clock
Setting Westminster chimes in bulova mantel clock
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
http://usedclockparts.com/8-clock-movement-repairs/14-fix-a-clock-that-gongs-wrong
Jul 06, 2014 | Seiko Mantel Clock
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
May 18, 2010 | Seiko Mantel Clock
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me [email protected] I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Apr 24, 2010 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Apr 05, 2010 | Seiko Mantel Clock
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Feb 08, 2010 | Seiko Mantel Clock
Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Jan 09, 2009 | Seiko Mantel Clock
Home Logo
587 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
